08-20-2021 01:44 PM - edited 08-20-2021 01:45 PM
Leaf -N9K-C9336C-FX2
Leaf 301-302 ,Port -23,vpc,speed-40g,epg1301.physical domain.
Problem- Led on port 23 of leaf301 is flashing green and amber continuosly.
While led of port 23 of leaf 302 is solid green.
Actions taken- when Removed trancievers from port 23 of leaf 301 at time also observed same behaviour.
There is one more vpc with port 24 with same config and observing same led problem which is only on leaf 301 24 port.
Is it cosmetic problem, hardware/led problem or configuration problem
Solved! Go to Solution.
10-01-2021 10:28 AM
Raised a Cisco TAC and it turned out to be cosmetic issue which was resolved after restarting a LEAF
08-20-2021 02:49 PM
Which version of code are you running?
Do you have DOM enabled on your switches?
Clarify your above statement - when you remove the transceiver on Leaf301, Port 23, do you see the Green/Amber flashing behavior move to the other Leaf (302 Port 23)?
Robert
08-20-2021 03:02 PM
Also, do you see any faults raised on either Leaf switch?
08-22-2021 08:21 PM
10-01-2021 10:28 AM
