Monitor Cisco APIC ( C220M4) via SNMP Best Practise ?
maamann
Is there a official Best Practice Example available for monitoring APIC´s .
For Example:
Use for hardware purposes only the CIMC IP and for ACi Fabric Related Stuff only APIC OOB IP ?
Why I am asking is I can not monitor the Harddisk Status via SNMP if i use the APIC OOB IP .
How do you monitor a UCS C220 for Power Supply status , HDD , Memory , etc. ??
Regards Markus
Hi omz
Could you please help me where i have to find the information about HD status , HD errors etc. unter this link.
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/mib/list/mib-support.html
regards Markus
Hi Markus
I cannot see HDD/Storage under MIBs Supported by APIC -https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/mib/list/mib-support.html
I think you have to use the UCS MIB from storage info polling.
ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/ucs-C-supportlist.html
Hi omz
That MIB
is to use with the CIMC  right ?
That would mean i can not monitor a APIC with only one IP Address to get all the needed informations to check the heath Status ?
You always need to snmp poll the APIC and the CIMC IP to get all informations about the health status
Regards Markus
