02-02-2021 11:10 AM
Hello all,
I'm honestly curious if anyone knows what "rsp" stands for in the advanced filter option rsp-subtree of moquery in ACI ?
My guess would be that it may be shorthand for "response", or perhaps it stands for "Request Scope Property" ?
Solved! Go to Solution.
02-02-2021 11:49 AM
Based on the description from ACI REST API documentation, I would say is simply short for "response".
For objects returned, this option specifies whether child objects are included in the response. This list describes the available choices:
no —(Default) Response includes no children.
children —Response includes only the children.
full —Response includes the entire structure including the children
Good question though.
Sergiu
02-02-2021 11:49 AM
Sergiu
02-02-2021 11:55 AM
Thanks! I had actually also looked at that link and those descriptions is what led me to think it may stand for "Response." I like learning what those things stand for as it helps me remember the syntax a bit better. Thanks for the confirmation!
02-02-2021 02:45 PM
I was going to suggest:
Reply Sergiu Please
- but you beat me to it!
02-02-2021 11:14 PM
02-02-2021 12:49 PM
