04-08-2020 06:51 AM
For some reason I can't find the answer to this...
MSO gets deployed as a cluster of 3-nodes. Done it, been there, got the t-shirt, but.....
Can it get deployed for more than 3-nodes? A question from a customer that I can't find an answer for.
I can't see why not, but I can why it you shouldn't have to as well.
Thanks in advance
Solved! Go to Solution.
04-09-2020 08:13 AM
we only support up to 3 nodes in the cluster. what is your use-case for having more nodes in the cluster ?
04-09-2020 08:13 AM
04-09-2020 08:20 AM
thanks for the answer, I have not use case to justify 4 nodes. A customer asked & I could not give them a confirmed answer. I have always deployed 3 nodes, but they asked me if it could do 4.
The answer is NO, which suits me fine. I can now continue with my design as expected.
