632
DanLaden
Beginner
Multi-Site Orchestrator Configuraiton Parity with APIC
How does one configure options that are avialable in the APIC but not in the MSO?
Case in point,  I would like to configure the DHCP  Relay on an interface and define a primary address where multiple subnets are present.
I cannot get either value in MSO.  In the APIC, i can create the DHCP relay object but get a warning when configuring primary address.  When I configure the subnet with "Make this virtual IP address primary", i get the following message.
"This has been created from Multi-Site. It is recommended to only make changes from Multi-Site. Please review the documentation before making any changes here."
Is there a mean to set values in MSO that are not visible in the GUI but are in APIC? MSO 1.2.
If the object in create in APIC and imported into MSO, are the object not in MSO GUI cleared from the config?
Thank You,
Dan Laden
0 REPLIES 0
