09-12-2018 08:38 AM - edited 03-01-2019 05:38 AM
Dears,
I established multipod between DC and DR, and i tried to verify the configuration and output i found that when i go to spine --- protocol --- bgp --- next-hop, id didn't any ip addess on next-hop, however if i connect any pc in dc and dr is pinging?
how can i solve this issue? or this is normal.
Solved! Go to Solution.
09-13-2018 06:22 PM
09-13-2018 06:22 PM
09-16-2018 04:25 AM
Hi Ranraju,
Thanks for reply, the issue is solved.
Thanks again
04-14-2019 09:46 AM
hi, I have the same problem, how did u fix it?
