12-07-2015 10:26 AM - edited 03-01-2019 04:54 AM
I am attempting to convert a Nexus 9396 from ACI to standalone mode. i've followed the some online documentation. The image is in the bootfash:
n9000-dk9.6.1.2.I3.4b.bin. I configure the switch to boot the image. and I get the following error. Is there a step I am missing?
Filesystem type is ext2fs, partition type 0x83
No autoboot or failed autoboot. falling to loader
04-20-2017 05:34 AM
I did, no go. bootflash seems corrupted or failed.
I also tried cmdline init_system clear_conf clear_log
Error:
Boot disk not found, Resetting EUSB bootflash
****BOOT DISK NOT FOUND****
Here's the console capture:
loader > cmdline recoverymode=1
loader > boot usb1:nxos.7.0.3.I4.5.bin
Booting usb1:nxos.7.0.3.I4.5.bin
Trying diskboot
Filesystem type is fat, partition type 0xb
Image valid
Image Signature verification was Successful.
Boot Time: 4/20/2017 12:13:10
[ 38.385856] [1492690429] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000ff00
[ 38.385858] [1492690429]
[ 38.521822] [1492690429] Pid: 1, comm: init Not tainted 3.4.91-WR5.0.1.13_standard+ #1
[ 38.616323] [1492690429] Call Trace:
[ 38.658907] [1492690429] [<ffffffff816ff918>] panic+0x11e/0x240
[ 38.730559] [1492690429] [<ffffffff8104e34e>] do_exit+0x42e/0x890
[ 38.804288] [1492690429] [<ffffffff8104eb10>] do_group_exit+0x80/0xb0
[ 38.882176] [1492690429] [<ffffffff8104eb57>] sys_exit_group+0x17/0x20
[ 38.961100] [1492690429] [<ffffffff817126a9>] ia32_do_call+0x13/0x13
CISCO SWITCH Ver7.41
Device detected on 0:6:0 after 0 msecs
Device detected on 0:1:1 after 0 msecs
Device detected on 0:1:0 after 0 msecs
MCFrequency 1333Mhz
Relocated to memory
Time: 4/20/2017 12:14:11
Detected CISCO IOFPGA
Donner Present
MIFPGA Present
Code Signing Results: 0x0
Using Upgrade FPGA
Checking and setting PSU fan directions
Booting from Primary Bios
FPGA Revison : 0x8
FPGA ID : 0x1345727
FPGA Date : 0x20160526
Power Debug Register: 0x0
Reset Cause Register: 0x80000004
Boot Ctrl Register : 0xe0ff
FPGA Update Status : 0x20
Detected CISCO MIFPGA
Version 2.16.1240. Copyright (C) 2013 American Megatrends, Inc.
Board type 2
IOFPGA @ 0xc8000000
SLOT_ID @ 0xf
Standalone chassis
check_bootmode: grub: Continue grub
Trying to read config file /boot/grub/menu.lst.local from (hd0,0)
Trying to read config file /boot/grub/menu.lst.local from (hd1,4)
Trying to read config file /boot/grub/menu.lst.local from (hd1,5)
Loader Version 7.41
loader > dir
usb1::
aci-n9000-dk9.12.2.1o.bin
aci-n9000-dk9.12.2.2e.bin
n9000-epld.7.0.3.I4.5.img
nxos.7.0.3.I4.5.bin
bootflash::
loader >
If I boot the ACI image I get to the bash-4.2# prompt
but I don't know what to do at that prompt and it reboots shortly after.
loader > boot usb1:aci-n9000-dk9.12.2.2e.bin
Booting usb1:aci-n9000-dk9.12.2.2e.bin
Trying diskboot
Image valid
Boot Time: 4/20/2017 12:17:53
[ 0.000000] Reserving ebda at 0x9f000 Len 0x61000
Z▒▒W▒▒j▒ZSk▒Sk▒Sk▒Sk▒ZR▒BSk▒VSk▒▒[ 6.493162] sd 5:0:0:0: [sda] No Caching mode page found
[ 6.558401] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 6.639676] sd 5:0:0:0: [sda] No Caching mode page found
[ 6.703106] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 6.783442] sd 5:0:0:0: [sda] No Caching mode page found
[ 6.846874] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 20.166465] ata5.00: failed to set xfermode (err_mask=0x4)
[ 35.737653] ata5.00: failed to set xfermode (err_mask=0x4)
[ 51.308837] ata5.00: failed to set xfermode (err_mask=0x4)
switching root to tmpfs
INIT: version 2.88 booting
Usage: grep [OPTION]... PATTERN [FILE]...
Try `grep --help' for more information.
Found card_index=21025
*** Running INXOS PE IFC image ***
Executing /etc/rc.d/rcS.d/S10mount-ramfs
Total memory: 16399656
Using new partition sizes as sup memory is 8G
Mounting /var
Mounting /etc
Mounting /nxos/tmp
Mounting /var/log
Mounting /var/home
Mounting /var/tmp
Skip /var/sysmgr setup to S26 script HW: 1, IFC: 1
Mounting /nginx
Mounting /dev/shm
Mounting /volatile
Mounting /debug
VDC_PREFIX = vdc_
VDC_PREFIX = vdc_
VDC_PREFIX = vdc_
Starting udev
e2fsck 1.42.1 (17-Feb-2012)
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-cfg0
Possibly non-existent device?
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-cfg1
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-pss
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-bootflash
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-logflash
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-recovery
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-ifc-cfg
/sbin/e2fsck: No such file or directory while trying to open /dev/hd-ifc-log
Early mount of filesystems
mount: special device /dev/hd-bootflash does not exist
mount: mount point /mnt/ifc/cfg does not exist
Starting Bootlog daemon: bootlogd.
Starting mcelog daemon
mount: special device /dev/hd-cfg0 does not exist
umount: /mnt/cfg/0: not mounted
Number of vdcs supported = 4
Executing /etc/rc.d/rcS.d/S26check-flash
Enter system maintenance mode? (y/n) [n]: ### For now falling back to system mode always ###
Checking partition structure
ls: cannot access /dev/hd-bootdev: No such file or directory
Warning: Unable to open /dev read-write (Is a directory). /dev has been opened
read-only.
read-only.
Error: /dev: unrecognised disk label
Total disk size (MB)0
read-only.
read-only.
read-only.
read-only.
Total free space (MB)0
Total partitions found 0
ERROR: Two few partitions
Unexpected Partitioning structure. Fixing it
WARNING: Reformatting disks
/bin/cp: cannot stat `/bootflash/golden-insieme-image': No such file or directory
/bin/cp: cannot stat `/bootflash/startup-cfg': No such file or directory
/bin/cp: cannot stat `/bootflash/mysetup.sh': No such file or directory
/bin/cp: cannot stat `/bootflash/isim.conf*': No such file or directory
/bin/cp: cannot stat `/bootflash/aci-n9000-dk9.12.2.2e.bin': No such file or directory
/bin/cp: cannot stat `/mnt/cfg/0/boot/grub/menu.lst.*': No such file or directory
Usage: umount -h | -V
umount -a [-d] [-f] [-r] [-n] [-v] [-t vfstypes] [-O opts]
umount [-d] [-f] [-r] [-n] [-v] special | node...
Warning: Unable to open /dev read-write (Is a directory). /dev has been opened read-only.
security_password="cisco"
/dev/:
Issuing SECURITY_SET_PASS command, password="cisco", user=user, mode=high
SECURITY_SET_PASS: Inappropriate ioctl for device
/dev/:
Issuing SECURITY_ERASE command, password="cisco", user=user
HDIO_DRIVE_CMD(identify) failed: Inappropriate ioctl for device
ERASE_PREPARE: Inappropriate ioctl for device
/dev/:
read-only.
read-only.
/isanboot/sbin/init-system: line 67: [: -gt: unary operator expected
read-only.
read-only.
mkfs.fat 3.0.22 (2013-07-19)
/dev/1: No such file or directory
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
read-only.
mke2fs 1.42.1 (17-Feb-2012)
Could not stat /dev/2 --- No such file or directory
The device apparently does not exist; did you specify it correctly?
Could not stat /dev/3 --- No such file or directory
Could not stat /dev/4 --- No such file or directory
Could not stat /dev/5 --- No such file or directory
Could not stat /dev/6 --- No such file or directory
Could not stat /dev/7 --- No such file or directory
Could not stat /dev/8 --- No such file or directory
Could not stat /dev/9 --- No such file or directory
Erasing 128 Kibyte @ 60000 -- 100 % complete
Erasing 128 Kibyte @ 20000 -- 100 % complete
Erasing 128 Kibyte @ be0000 -- 100 % complete
Erasing 128 Kibyte @ 31e0000 -- 100 % complete
Remounting file systems
mount: special device /dev/hd-cfg1 does not exist
mount: special device /dev/hd-pss does not exist
mount: mount point /logflash does not exist
mount: mount point /recovery does not exist
mount: special device /dev/hd-ifc-cfg does not exist
mount: mount point /mnt/ifc/log does not exist
mount: unknown filesystem type 'vfat'
mount: mount point /usb/usb2 does not exist
/bin/mv: cannot stat `/dev/shm/golden-insieme-image': No such file or directory
/bin/mv: cannot stat `/dev/shm/startup-cfg': No such file or directory
/bin/mv: cannot stat `/dev/shm/mysetup.sh': No such file or directory
/bin/mv: cannot stat `/dev/shm/isim.conf*': No such file or directory
/bin/cp: cannot stat `/dev/shm/aci-n9000-dk9.12.2.2e.bin': No such file or directory
/bin/mv: cannot stat `/dev/shm/menu.lst.*': No such file or directory
Checking all filesystems.mount: special device /dev/hd-cfg0 does not exist
Checking cfg0
ls: cannot access /dev/hd-cfg0: No such file or directory
Fsck on /mnt/cfg/0
umount2: Invalid argument
RPARTITION BAD. EXIT TO REFORMAT AND CONTINUE
bash-4.2#
bash-4.2# [ 559.209458] Uhhuh. NMI received for unknown reason 21 on CPU 0.
[ 559.280176] Do you have a strange power saving mode enabled?
[ 559.347841] Dazed and confused, but trying to continue
bash-4.2#
bash-4.2# cd dev
bash-4.2# ls
aer_inject ptyc9 ptys7 ptyy5 tty57 ttyef ttyuc
block ptyca ptys8 ptyy6 tty58 ttyp0 ttyud
bsg ptycb ptys9 ptyy7 tty59 ttyp1 ttyue
bus ptycc ptysa ptyy8 tty6 ttyp2 ttyuf
char ptycd ptysb ptyy9 tty60 ttyp3 ttyv0
cmos ptyce ptysc ptyya tty61 ttyp4 ttyv1
console ptycf ptysd ptyyb tty62 ttyp5 ttyv2
core ptyd0 ptyse ptyyc tty63 ttyp6 ttyv3
cpu ptyd1 ptysf ptyyd tty7 ttyp7 ttyv4
cpu_dma_latency ptyd2 ptyt0 ptyye tty8 ttyp8 ttyv5
fd ptyd3 ptyt1 ptyyf tty9 ttyp9 ttyv6
full ptyd4 ptyt2 ptyz0 ttyS0 ttypa ttyv7
fuse ptyd5 ptyt3 ptyz1 ttyS1 ttypb ttyv8
hd-usb1 ptyd6 ptyt4 ptyz2 ttyS2 ttypc ttyv9
hd-usbdev1 ptyd7 ptyt5 ptyz3 ttyS3 ttypd ttyva
initctl ptyd8 ptyt6 ptyz4 ttya0 ttype ttyvb
kbootctrl ptyd9 ptyt7 ptyz5 ttya1 ttypf ttyvc
kmem ptyda ptyt8 ptyz6 ttya2 ttyprintk ttyvd
kmsg ptydb ptyt9 ptyz7 ttya3 ttyq0 ttyve
kvm ptydc ptyta ptyz8 ttya4 ttyq1 ttyvf
loop-control ptydd ptytb ptyz9 ttya5 ttyq2 ttyw0
loop0 ptyde ptytc ptyza ttya6 ttyq3 ttyw1
loop1 ptydf ptytd ptyzb ttya7 ttyq4 ttyw2
loop2 ptye0 ptyte ptyzc ttya8 ttyq5 ttyw3
loop3 ptye1 ptytf ptyzd ttya9 ttyq6 ttyw4
loop4 ptye2 ptyu0 ptyze ttyaa ttyq7 ttyw5
loop5 ptye3 ptyu1 ptyzf ttyab ttyq8 ttyw6
loop6 ptye4 ptyu2 ram ttyac ttyq9 ttyw7
loop7 ptye5 ptyu3 ram0 ttyad ttyqa ttyw8
mcelog ptye6 ptyu4 ram1 ttyae ttyqb ttyw9
mem ptye7 ptyu5 random ttyaf ttyqc ttywa
mqueue ptye8 ptyu6 rtc ttyb0 ttyqd ttywb
mtd0 ptye9 ptyu7 rtc0 ttyb1 ttyqe ttywc
mtd0ro ptyea ptyu8 sda ttyb2 ttyqf ttywd
mtd1 ptyeb ptyu9 sda1 ttyb3 ttyr0 ttywe
mtd1ro ptyec ptyua shm ttyb4 ttyr1 ttywf
mtd2 ptyed ptyub stderr ttyb5 ttyr2 ttyx0
mtd2ro ptyee ptyuc stdin ttyb6 ttyr3 ttyx1
mtd3 ptyef ptyud stdout ttyb7 ttyr4 ttyx2
mtd3ro ptyp0 ptyue tracedevice ttyb8 ttyr5 ttyx3
mtd4 ptyp1 ptyuf tty ttyb9 ttyr6 ttyx4
mtd4ro ptyp2 ptyv0 tty0 ttyba ttyr7 ttyx5
mtd5 ptyp3 ptyv1 tty1 ttybb ttyr8 ttyx6
mtd5ro ptyp4 ptyv2 tty10 ttybc ttyr9 ttyx7
mtd6 ptyp5 ptyv3 tty11 ttybd ttyra ttyx8
mtd6ro ptyp6 ptyv4 tty12 ttybe ttyrb ttyx9
net ptyp7 ptyv5 tty13 ttybf ttyrc ttyxa
network_latency ptyp8 ptyv6 tty14 ttyc0 ttyrd ttyxb
network_throughput ptyp9 ptyv7 tty15 ttyc1 ttyre ttyxc
null ptypa ptyv8 tty16 ttyc2 ttyrf ttyxd
port ptypb ptyv9 tty17 ttyc3 ttys0 ttyxe
ptmx ptypc ptyva tty18 ttyc4 ttys1 ttyxf
pts ptypd ptyvb tty19 ttyc5 ttys2 ttyy0
ptya0 ptype ptyvc tty2 ttyc6 ttys3 ttyy1
ptya1 ptypf ptyvd tty20 ttyc7 ttys4 ttyy2
ptya2 ptyq0 ptyve tty21 ttyc8 ttys5 ttyy3
ptya3 ptyq1 ptyvf tty22 ttyc9 ttys6 ttyy4
ptya4 ptyq2 ptyw0 tty23 ttyca ttys7 ttyy5
ptya5 ptyq3 ptyw1 tty24 ttycb ttys8 ttyy6
ptya6 ptyq4 ptyw2 tty25 ttycc ttys9 ttyy7
ptya7 ptyq5 ptyw3 tty26 ttycd ttysa ttyy8
ptya8 ptyq6 ptyw4 tty27 ttyce ttysb ttyy9
ptya9 ptyq7 ptyw5 tty28 ttycf ttysc ttyya
ptyaa ptyq8 ptyw6 tty29 ttyd0 ttysd ttyyb
ptyab ptyq9 ptyw7 tty3 ttyd1 ttyse ttyyc
ptyac ptyqa ptyw8 tty30 ttyd2 ttysf ttyyd
ptyad ptyqb ptyw9 tty31 ttyd3 ttyt0 ttyye
ptyae ptyqc ptywa tty32 ttyd4 ttyt1 ttyyf
ptyaf ptyqd ptywb tty33 ttyd5 ttyt2 ttyz0
ptyb0 ptyqe ptywc tty34 ttyd6 ttyt3 ttyz1
ptyb1 ptyqf ptywd tty35 ttyd7 ttyt4 ttyz2
ptyb2 ptyr0 ptywe tty36 ttyd8 ttyt5 ttyz3
ptyb3 ptyr1 ptywf tty37 ttyd9 ttyt6 ttyz4
ptyb4 ptyr2 ptyx0 tty38 ttyda ttyt7 ttyz5
ptyb5 ptyr3 ptyx1 tty39 ttydb ttyt8 ttyz6
ptyb6 ptyr4 ptyx2 tty4 ttydc ttyt9 ttyz7
ptyb7 ptyr5 ptyx3 tty40 ttydd ttyta ttyz8
ptyb8 ptyr6 ptyx4 tty41 ttyde ttytb ttyz9
ptyb9 ptyr7 ptyx5 tty42 ttydf ttytc ttyza
ptyba ptyr8 ptyx6 tty43 ttye0 ttytd ttyzb
ptybb ptyr9 ptyx7 tty44 ttye1 ttyte ttyzc
ptybc ptyra ptyx8 tty45 ttye2 ttytf ttyzd
ptybd ptyrb ptyx9 tty46 ttye3 ttyu0 ttyze
ptybe ptyrc ptyxa tty47 ttye4 ttyu1 ttyzf
ptybf ptyrd ptyxb tty48 ttye5 ttyu2 ubi_ctrl
ptyc0 ptyre ptyxc tty49 ttye6 ttyu3 urandom
ptyc1 ptyrf ptyxd tty5 ttye7 ttyu4 vcs
ptyc2 ptys0 ptyxe tty50 ttye8 ttyu5 vcs1
ptyc3 ptys1 ptyxf tty51 ttye9 ttyu6 vcsa
ptyc4 ptys2 ptyy0 tty52 ttyea ttyu7 vcsa1
ptyc5 ptys3 ptyy1 tty53 ttyeb ttyu8 vga_arbiter
ptyc6 ptys4 ptyy2 tty54 ttyec ttyu9 vhost-net
ptyc7 ptys5 ptyy3 tty55 ttyed ttyua zero
ptyc8 ptys6 ptyy4 tty56 ttyee ttyub
bash-4.2#
bash-4.2#
MCFrequency 1333Mhz
Relocated to memory
Time: 4/20/2017 12:31:21
Donner Present
MIFPGA Present
Using Upgrade FPGA
FPGA Revison : 0x8
FPGA ID : 0x1345727
Board type 2
IOFPGA @ 0xc8000000
SLOT_ID @ 0xf
Standalone chassis
Loader Version 7.41
loader >
12-07-2015 12:15 PM
You should be able to recover from the loader prompt with the following steps:
1) Copy Image from USB to bootflash:
Loader > dir usb1:
Loader > copy usb1:<ACI Image Name> bootflash:
Or
Loader > dir usb2:
Loader > copy usb2:<ACI Image Name> bootflash:
2) Clear previous configuration, initialize filesystem:
Loader > cmdline init_system clear_config clear_log
3) Boot new image:
Loader > dir
Loader > boot bootflash://<ACI Image Name>
OR
Boot the Cisco Nexus 9000 Series ACI-Mode image from hosting server. For this method, Use TFTP. Use the command, "boot tftp://<tftpserver_ip>/<path>/<ACI_IMAGE.bin>".
12-07-2015 12:21 PM
copy is not a recognized command from the loader prompt.
12-07-2015 11:08 AM
Hi aleccham,
the switch will not even stop at the kickstart..
12-07-2015 10:44 AM
Pasa,
From the loader prompt, list the contents of bootflash. Capture the output and paste the response to the forum.
Loader > dir
T.
12-07-2015 10:49 AM
I issued the system_init and now the nx-os image is no longer in the bootflash. and i can only get to the loader prompt.
12-07-2015 10:54 AM
Pasa,
Loader > dir
T.
