801
network1215
Beginner
Nexus N9K-C9348GC-FXP in ACI Mode upgrade
Hi All,
I am bringing up fabric with APIC version 4.1(1l). some of the leaf we received has older code and I would like to upgrade as stand alone switches/leaf before APIC can discover the leafs. Unfortunately My APIC is unable to discover these leaf switches with older code.
current code on APIC: 4.1(1I)
Leaf 1 current code on Leaf (N9K-C9348GC-FXP)
BIOS: version 05.39
kickstart: version 13.2(9f) [build 13.2(9f)]
system: version 13.2(9f) [build 13.2(9f)]
PE: version 3.2(9f)
I am looking for upgrade procedure using the CLI but unable to find it. I mean console into each leaf and move file from USB to switch and upgrade.
Do I have to upgrade BIOS or other images as well.
1 ACCEPTED SOLUTION
Robert Burns
My  advise (to make this easier & faster) is discover the Leafs at the version they are.  As long as they are lower than the APIC, shouldn't be any issue.  Once discovered, then you easy do a policy upgrade which will upgrade the bios/fpga/ACI image.
Robert
4 REPLIES 4
Robert Burns
Robert
unfortunately,  I am unable to discover the leaf switches via APIC. They are not showing up in controller GUI. That is why I was thinking it is probably IOS version issue.
Nah, wouldn't be an issue with the Leaf version as to your discovery issue.  Likely a Date/Time and/or Cert issue.  Have you checked these?
Robert
you are write.. I reload my leaf's one more time and than they appeared in APIC.. Now I will use the GUI for the upgrade.
Thanks.
