OSPF process does not start on a LEAF
atcapaev
   Hello Experts,
I am troubleshooting a very obscure problem.
I have created an External routed L3out OSPF profile and applied it to to Leaf 102.
I have also specify the interface selector which is 1/1
I have also confifured L3 routed interface for OSPF (192.168.3.1) which I can ping from a router attached to the leaf.
Thhe problem here that i see is that the process is not running
leaf102# show ip ospf interface vrf all
leaf102#
leaf102# show ip ospf event-history internal event-history
Incorrect command "show ip ospf event-history internal event-history"
leaf102# show ip ospf event-history internal event-history verbose
Found Tag value: event-history
Note:  process currently not running
There are some log messages which I tryed to understand  but unfortunately don't see a lot of sence in them
leaf102# show ip ospf event-history verbose
OSPF VERB events for Process "ospf-multipodInternal"
2018 Oct 24 22:39:35.472029 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:35.471491 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:35.471023 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:35.470649 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:35.470079 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:35.469505 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:35.469050 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.915209 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.906879 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.906572 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.705049 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.704970 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.700717 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 51201 from SAP 365
2018 Oct 24 22:39:30.697921 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.697831 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.697779 ospf multipodInternal [11815]: TID 11949:ospf_handle_im_if_create:2954: FAILURE: Find PriKey from SecKey! rv:1
2018 Oct 24 22:39:30.697763 ospf multipodInternal [11815]: TID 11949:ospf_handle_im_if_create:2938: Received MTS_OPC_IM_IF_CREATED notification for ifindex: 0x18010019, iod: 74
2018 Oct 24 22:39:30.697733 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62467 from SAP 393
2018 Oct 24 22:39:30.111707 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.107619 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.097260 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.094610 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.092620 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.085801 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.079687 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.077218 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.074913 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.072899 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.067058 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.065967 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.062309 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.058096 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.052974 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62472 from SAP 393
2018 Oct 24 22:39:30.040210 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.038056 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.034801 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 51201 from SAP 365
2018 Oct 24 22:39:30.033205 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.031414 ospf multipodInternal [11815]: TID 11949:ospf_handle_im_if_create:2954: FAILURE: Find PriKey from SecKey! rv:1
2018 Oct 24 22:39:30.031400 ospf multipodInternal [11815]: TID 11949:ospf_handle_im_if_create:2938: Received MTS_OPC_IM_IF_CREATED notification for ifindex: 0x18010016, iod: 73
2018 Oct 24 22:39:30.031373 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62467 from SAP 393
2018 Oct 24 22:39:30.030242 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.028982 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.026606 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 51201 from SAP 365
2018 Oct 24 22:39:30.024455 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.022653 ospf multipodInternal [11815]: TID 11949:ospf_handle_im_if_create:2954: FAILURE: Find PriKey from SecKey! rv:1
2018 Oct 24 22:39:30.022638 ospf multipodInternal [11815]: TID 11949:ospf_handle_im_if_create:2938: Received MTS_OPC_IM_IF_CREATED notification for ifindex: 0x18010018, iod: 72
2018 Oct 24 22:39:30.022613 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62467 from SAP 393
2018 Oct 24 22:39:30.021200 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.020199 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.018328 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.017606 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
2018 Oct 24 22:39:30.016463 ospf multipodInternal [11815]: TID 11949:ospf_ipc_mts_thread:5808: Received MTS message with opcode 62484 from SAP 393
Could you tell me please if you have seen similar issue or have any suggestion?
I tryed reloading the leaf which didn't help.
micgarc2
Can you verify your logical interface profile has an OSPF Interface Profile tied to it. Without that OSPF process will not start.
-Michael G.
 Hello Michael!
Thhank you very much for suggestion.
I indeed had interface profiled tied node profile.
Strangly ebough after a few times reconfiguring L3out I tryed creating it with Loopback unchecked and it helped.
I had already had another L3 profile on another node so I guess the loopback somehow would conflict with previous one. Otherwise I have no clue why it helped.
