01-25-2021 11:11 AM
Hi!
I am trying to test how the route-maps are working in ACI. I have an OSPF interco with a router.
I have tested the "default-export" route-map, it permits to:
First question, my subnets are not redistributed with advertised externally and Match prefix (for the route-map) if not explicitly configured, why ? Seems like it should be redistributed with match prefix and policy.
Second test with a named route-map (not default). I create it under my L3Out, with rules for my subnets:
Seems like I can't make work a route-map that is not the default one.
Do you have any idea what is wrong?
Jérémy
01-25-2021 11:39 PM
I'm using APIC 4.2(4) and this doc https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/application-policy-infrastructure-controller-apic/211586-ACI-Route-Profile-Usage.html
Did anyone try to work with route-map (not default) ?
01-26-2021 06:53 AM
We are using route maps for route control with BGP with no issues. V 4.2.4 and now 4.2.6
01-26-2021 07:02 AM
You are using route-map that are not default-export ? You just configure it under your L3Out, then apply it under the BD and it is redistributed ?
01-26-2021 07:33 AM
Route Map For Import and Export Route Control
Policiers > Protocols > Route maps for route control
01-26-2021 07:51 AM
When I create it under the menu you give, I can't use it anywhere. Not under L3Out, not under BD, ...
Could you help me I must be doing something wrong.
01-26-2021 08:35 AM
01-26-2021 10:08 AM
Yes I know this doc.. I wanted to know more about your implementation. Understand why I can't make the custom RM work and especially why I can't select it under other menus when it is created under Policies
01-26-2021 12:08 PM
The same profile is used by multiple L3OUTs, therefore profile is in
In L3OUT:
L3OUT >> Logical Node profile >> LEAF >>>Logical interface profile >>> PORT >>> BGP peer connection profile
here route profiles are applied.
01-27-2021 12:17 AM - edited 01-27-2021 04:25 AM
Ok that doesn't exist in OSPF. Thank you.
Did someone try route-map with OSPF ?
