Questions about BD, VLAN, default gateway
bo liu
Level 4
Level 4
hello everyone
I'm going to be managing an ACI system, so I'm learning about ACI.  I have a question that has always puzzled me.
From my understanding,BD is a Layer 2 boundary rather than a VLAN. Configure subnet under BD as the default gateway for the endpoint. In addition, EPG encapsulates VLAN tags. My question is, how does an endpoint know that it belongs to that BD subnet.
For example, a BD contains five subnets from 192.168.1.1/24 to 192.168.5.1/24, There are two EPGs, EPG1 and EPG2. EPG1 encapsulates VLAN10, and EPG2 encapsulates VLAN20.
Therefore, the endpoint in EPG1 and EPG2 can belong to the 192.168.1.0/24 network segment and the default gateway is 192.168.1.1? Don't care about VLAN encapsulation?
2 Accepted Solutions
Robert Burns
Bo,
From an object model perspective, an EPG is associated to one (and only one) BD.  The Endpoint has no knowledge of it's BD but we know as the Admins which BDs an EPG has been assigned to.   You're correct in that any EPG (regardless of it's IP) will be able to reach any Subnet SVI of it's associated BD.   For the Endpoint to be able to route, it the BD would need to have unicast routing enabled (assuming the Endpoint is using the BD Subnet as it's GW).   While this may be confusing, its one of the benefits that ACI offers in terms of network abstraction.
Take this example
Endpoint_A = 192.168.1.1 (Belongs to EPG_A)
Endpoint_B = 192.168.1.2 (Belongs to EPG_B)
BD_1 Subnet = 192.168.1.254/24
EPG_A is associated with BD_1
EPG_B is associated with BD_1
In this example, even though my endpoints are spread across EPGs (different Encaps) and associated to the same BD - they would not be able to communicate.  Not without a contract that is.  This is where ACI shines by separating routing (network) from policy (security).
So to answer your question, the encap only matters for endpoint assignment, and has nothing to do with policy.
Make sense?
Robert
Sergiu.Daniluk
Hi @bo liu
This is how you can look at it:
Encap VLAN = the way you tell a leaf in which EPGs to learn endpoints on that specific leaf (remember, you can have static ports assignments with different vlans on different leafs part of same EPG)
EPG = what you use to perform policy enforcement and segmentation in a specific BD
BD = what you use to define your broadcast domain (if routing is enabled, this is translated to an SVI on the leafs, with one or more subnets configured on it)
Stay safe,
Sergiu
Robert Burns
Bo,
Take this example
Make sense?
Robert
Hi Robert
Thanks for your reply.
So suppose:
I have a BD (BD-1) with 2 subnets: 192.168.1.1/24, 172.16.1.1/24, 192 for WebServer, 172 for DBserver.
So I can define two EPGs as two separate businesses:
EPG1 = 192.168.1.10(Web Server) + 172.16.1.10(DB server)
EPG2 = 192.168.1.20(Web server) + 172.16.1.20(DB server)
All endpoints point the default gateway to BD's subnet
In addition, when I need to leak these addresses to another VRF, BD-1 is the provider. I can define subnet in EPG1:192.168.1.10/32 and 172.16.1.10/32 and set scope to shared VRF.
Is that correct?
Sergiu.Daniluk
Hi @bo liu
Stay safe,
Sergiu
