Webcast -VXLAN BGP EVPNt
218
Beginner
Replace ACI leaf node with a different model
I have a small ACI fabric in prod. I need to replace a 9300 leaf with another different 9300 model. I would like to keep using the same node Id and node name. So the related policies are pushed by APIC. I know this works for the same model of switches, such as for RMA. But I am not sure if that works for different switch models. The two different switches are the same generation though.
1 ACCEPTED SOLUTION
Re: Replace ACI leaf node with a different model
3 REPLIES 3
Highlighted
Beginner
Thanks, I do have that link and as matter of fact, I did put in a comment for that article asking the same thing :)
Beginner
Here's the exact procedure on 4.1.1i
Virtual Port Channel Migration - Migration of Nodes from a First-Generation Switch to a Second-Generation Switch
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/aci_hig/guide/b_aci_hardware_install_guide/b_aci_hardware_install_guide_chapter_011.html#id_97986
Ask the Expert French- routing protocols
