Same VLAN's convergence from Separate Environments for Cisco ACI
balbaletabrez
Hello Experts,
Need your assistance to configure the existence of same VLAN's 900 in 3 different environments eg PROD, NONPROD and MGMT, VLAN 900 exists in all 3 (Its is a brownfield and currently does exists), Now Cisco ACI is introduced (Greenfield) in this environment for Configuring VLAN 900 of PROD is not an issue, the concern here is the other environments NONPROD and MGMT once configured in the ACI wont it cause overlapping of IP's and Subnets including the VLAN?? cannot change as the GW resides in PA FW with Specific Static Routes.
So please help me to understand better, i know the external VLAN info hold no relevance in ACI as VxLAN takes over, also for overlapping there is VNI which will be added for segregation, so how do i migrate?? Can you help with the CLI commands, Also configuring all the environments on separate Leaf switches may isolate the problem?? Changing the existing configuration is not an option.
RedNectar
Hi @balbaletabrez ,
It sounds like you need to configure three tenants. PROD, NONPROD and MGMT
VLAN IDs are specific per tenant, and local to each ACI Leaf switch - but there is a small problem if VLAN 900 exists on the SAME switch for two different Tenants. In this case you need to ensure that the Interface Policy Group of at least one of the Tenants has a L2 Interface Policy that specifies Per Port VLAN as explained here.
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
Hi @balbaletabrez ,
I hope this helps
Thanks RedNectar,
One more help please.....how to migrate SVI's to ACI, can you point to the link or help with the cli commands for the VLAN/SVI migration to ACI, I understand its VLAN = EPG = BD.
I did ask for help on this before but i am pointed to documents for long read....i just need CLI commands to do the migration, also it will help to built up a migration script.
