08-09-2016 09:23 AM - edited 03-01-2019 05:00 AM
Hi guys!
We're hitting a 'data plane partially diverged' on two controller nodes. The initial situation was that one of the APICs (APIC ID1)had died after a reboot due to HW faults ( after a reboot to with FW upgrade to 2.0). We decommissioned the faulty controller and powered it off and unplugged power. The remaining two APICs then got into split brain/'data plane partially diverged'. After rebooting both APICs sequentially the problem was still present and we decided to decomission and recomission APIC ID 3 but to no avail.
Any ideas?
P
08-10-2016 07:34 AM
Petar,
Thank you for contacting the Cisco Support Community for ACI. I am sorry that you are having an issue with the APIC Cluster. I am going to summarize the issue so please correct me if my understanding is incorrect.
This will most likely be the best way for us to determine the next plan of action.
T.
08-11-2016 06:43 AM
We resolved the problem by decomissioning the HW faulty APIC, and by resetting the non-leader to the setup wizzard. That resolved the split brain by some force :)
