560
CK_Bengre
Beginner
Total Egress Bytes Rate vs Total Egress Bytes - APIC stats
Hi Team ,
How to read the stats in APIC controller for EP connected interface in APIC controller .
What is the difference between Total Egress Bytes Rate vs Total Egress Bytes ?
Can someone tell me how do you read the interface bandwidth utilization value from the below screenshot . ACI interface Bandwidth.JPG
2 REPLIES 2
Robert Burns
"Total Egress Bytes Rate vs Total Egress Bytes"
This is a current throughput rate (over a 5min time period average by default) vs. a cumulative counter.  It's the same as you'd see on any switch with a "show int x/y" output.  It's meant to give you an idea of the throughput rate (egress & ingress) while giving the running total byte count.   These stats can be configured to throw alerts if you pass certain thresholds/values (set by a stats threshold policy).  Most customers will use these stats and the histogram to look at any spikes or dips in traffic that might potentially point to an issue or anomaly.
Robert
@Robert Burns So If I have to confirm the current bandwidth usage , I have to look for Total Egress/Ingress Bytes rate right ?
