05-18-2022 06:53 AM
Hello, my team has followed the deployment guide for the ACI Simulator 4.x on VMware ESXi. For some reason, I can see the vNIC mac addresses on the switches connected to the host, but I don't see the apic1-eth1 MAC address, and the VM won't respond to ping nor https requests. I verified that the vSwitch is in promiscuous mode.
What's weird is that this was incredibly easy to set up at home on VMware Workstation.
05-20-2022 05:14 AM
10 out of 10 times this is an issue with the vSwitch security and/or VM Resources (Memory/CPU). Flip on all the Port Group security options (Promiscuous, MAC Change, Forged MACs) and ensure you don't have any conflicting setting overrides.
To test this, put a test workstation directly on the same Port Group as the Simulator and see if you can ping it from there. That will eliminate a lot of potential issues.
Robert
05-24-2022 07:44 AM
Hi Josué,
As Robert mentioned, make sure you change the all the security settings in the vSwitch to "Accept". I just ran a quick test in the lab, enabling promiscuous mode only is not enough, you also need to accept MAC address changes and Forged transmits. A few seconds after changing the settings you should be able to reach the APIC's mgmt IP.
Hope this helps!
Javi
