03-08-2017 02:48 AM - edited 03-01-2019 05:10 AM
I should install an ACI fabric shortly, but my Spine switches order is delayed for some time.
So in the meantime, may i use 2 x N9K-C93180YC-EX border leafs, plus other two leaf switches of the same model meshed with 40Gbps interfaces to build an initial temporary ACI fabric with all of them while waiting for the spines?
Thanks in advance.
Albert.
Solved! Go to Solution.
03-08-2017 08:04 AM
Hi Albert
This won't work you need some specific functions of the spines in order to build your ACI-fabric.
Marcel
03-08-2017 08:04 AM
Hi Albert,
I've not tried it so I don't know what exactly will happen but I'm almost 100 % sure that it'll be a waste of time. The ASICs are different for Leaf and Spine switches so you're 93180YC-EX cannot run as Spine switches. Also you shouldn't (mustn't?) connect leaf switches so even considering it being a Non-Spine architecture won't work.
If you don't have anything else to do and have the time, go for it, (I would be curious where and how the system would stop you) but other than for educational purposes there is no point in even trying.
Nik
03-08-2017 08:04 AM
Hi Albert
Marcel
03-08-2017 08:04 AM
Hi Albert,
Nik
