Beginner
What protocols does APIC use to push policies and objects to switches and vCenter?
Is APIC using HTTPS/SSL or some other protocol to push out configuration to switches and vcenter? Is it based on TCP or UDP?
2 REPLIES 2
Beginner
Re: What protocols does APIC use to push policies and objects to switches and vCenter?
Protocols used are as follows:
1.Between APIC and ACI switches: Opflex protocol
2. Between APIC and Vcenter: HTTPS(if I am not wrong they communicate via APIs)
For more details on Opflex kindly refer below link:
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-731302.html
Hope that helps!
Jayesh
Beginner
Thanks, will read the link.
Content for Community-Ad
August's Community Spotlight Awards
