11150 Switch stops transmitting at random
jcy444
I have consistent problems with our 11150 switches, one will stop transmitting like it is the "backup" switch but it never transitions from being "master" so all traffic is stopped. It never shows a link failure or a state transition. There are no errors or drops on any of the next hop switches. We have replaced the hardware and still have the problem. Here is the error in the debug log:
MAR 3 22:52:27 5/1 425 FLOWMGR-7: Resetting port 2c01f00 ending at 114641
MAR 3 22:55:12 5/1 426 IPV4-7: Ipv4SfmForwRx: Ingress circuit non-exist
Gilles Dufour
what is the current software version ?
Could you capture a 'flow stat' from debug mode and send it to us.
Gilles.
The software version is 5.00 build 69
Here is the output:
flow stat
Flow Manager Statistics:
Cur High Avg
UDP Flows per second 0 0 0
TCP Flows per second 0 6 0
Total Flows per second 0 6 0
Hits per second 0 0 0
Number of Allocated Flows (non-purged) 0
Number of Free Flows 262144
Number of Flow Drops 0
Max Number of Flow Control Blocks 615757
Number of Flows with SynAckPending 0
Accumulated Port Flow Statistics:
Current Number of Active Flows 0
Total Flow Accounting Reports received 10
Total Out of Sequence Packet Received 0
Total Spoof Queue Mis-Hits 0
Port CE Active Total Acct TCP UDP Rst FCBs
#e1 1f00 0 0 0 0 0 0 15216
#e12 2c01f00 0 0 0 0 0 0 15216
#e13 3001f00 0 0 0 0 0 0 31600
#e14 3001f01 0 10 10 0 0 0 126440
Please standby on this as I see you have a TAC case open. We are investigating this with regards to EPIF resets on the CSS. The engineer you are working with was instructed to get a "flow statistics" in debug mode.
Pete Knoops
Cisco Systems
