ACE 4710 Forward Secrecy
greg.murray
Does the ACE 4710 support FS (Forward Secrecy)?
In respect of FS (Forward Secrecy) I found a nice link that discusses the cipher suites required to support this.
https://community.qualys.com/blogs/securitylabs/2013/06/25/ssl-labs-deploying-forward-secrecy?_ga=1.37950244.609993483.1431008577
In the nutshell, these are some of the suites we might want to enable and push (close) to the top:
    TLS_ECDHE_RSA_WITH_RC4_128_SHA
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
    TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
However what I cannot see is how this maps to the supported suites on the ACE.
ACE-4710(config-parammap-ssl)# cipher ?
  RSA_EXPORT1024_WITH_DES_CBC_SHA  Accept RSA_EXPORT1024_WITH_DES_CBC_SHA cipher
  RSA_EXPORT1024_WITH_RC4_56_MD5   Accept RSA_EXPORT1024_WITH_RC4_56_MD5 cipher
  RSA_EXPORT1024_WITH_RC4_56_SHA   Accept RSA_EXPORT1024_WITH_RC4_56_SHA cipher
  RSA_EXPORT_WITH_DES40_CBC_SHA    Accept RSA_EXPORT_WITH_DES40_CBC_SHA cipher
  RSA_EXPORT_WITH_RC4_40_MD5       Accept RSA_EXPORT_WITH_RC4_40_MD5 cipher
  RSA_WITH_3DES_EDE_CBC_SHA        Accept RSA_WITH_3DES_EDE_CBC_SHA cipher
  RSA_WITH_AES_128_CBC_SHA         Accept RSA_WITH_AES_128_CBC_SHA cipher
  RSA_WITH_AES_128_CBC_SHA256      Accept RSA_WITH_AES_128_CBC_SHA256 cipher
  RSA_WITH_AES_256_CBC_SHA         Accept RSA_WITH_AES_256_CBC_SHA cipher
  RSA_WITH_DES_CBC_SHA             Accept RSA_WITH_DES_CBC_SHA cipher
  RSA_WITH_RC4_128_MD5             Accept RSA_WITH_RC4_128_MD5 cipher
  RSA_WITH_RC4_128_SHA             Accept RSA_WITH_RC4_128_SHA cipher
Is it supported?
Kanwaljeet Singh
Hi Greg,
ACE doesn't support forward secrecy and there are no plans too. With A532 which was supposed to be the last ACE version to be released, i don't see this being implemented.
Kanwal
Note: Please mark answers if they are helpful.
Kanwaljeet Singh
Hi Greg,
Kanwal
Thank you for the post. Do you have a link or a document that refers to this? As I can't find anything?
ACE 4710 & ACE30 don't support forward secrecy. However, there is one more release coming in late August - A5(3.3) which should plug some more SSL bugs.
Does the ACE 4710 A5(3.5) support FS (Forward Secrecy)?
Thank's a lot.
