ACE 4710 load balancing HTTP cookie pattern not working
sololuke2013
I try to configure ACE 4710 LB A5(2.1) LB to do following:
1. client send a http request for login to WEB srv
2.  server response and send a cookie Set-Cookie with following pattern  JSESSIONID=C333C37FCF083D210A639ABB8BB9DB21.S01 (33 random body 3 char  string server ID)
3. Client send authorize http request to other server with the cookie in  URI (traffic not go via LB)
4. Authorize server send to WEB srv a request containing that cookie and wait for answer.
Client ----> ACE LB VIP ---> WEB server
Client -----> Authorize SRV ----> ACE LB VIP ----> WEB server
There are 4 WEB srv which have sessions ending in . S01 S02 S03 S04
I  want that all login request to be round robin balanced, and authorize  request to be forwarded to right WEB srv based on cookie termination S01  or .....
Configuration:
1. server farm probing
probe http http_8080
   port 8080
   interval 7
   passdetect interval 3
   passdetect count 4
   receive 2
   expect status 200 200
   open 3
2. cookie stickiness settings
sticky http-cookie JSESSIONID web-pro-srv-8080-stk
   cookie offset 33 length 3
   serverfarm WEB-pro-8080
   timeout 5
   replicate sticky
3. Traffic policy
class-map match-all WEB-pro-8080
   2 match virtual-address 192.168.123.100 tcp eq 8080
policy-map type loadbalance first-match WEB-pro-8080
   class class-default
     sticky-serverfarm web-pro-srv-8080-stk
policy-map multi-match EXTERNAL
  class WEB-pro-8080
     loadbalance vip inservice
     loadbalance policy WEB-pro-8080
     loadbalance vip icmp-reply active primary-inservice
Issue: Some sessions obtained at login are forwarded by LB      to wrong WEB srv
Can you please help me?
duplicate on
https://supportforums.cisco.com/message/4078336#4078336
rajsures
Hi Luke,
I am not sure why "cookie offset 33 length 3" is required here. Again the offset value 33 and length value 3 is actually configured in bytes and not exactly based on number of characters in the cookie value. What happens if you remove the
"cookie offset 33 length 3" from the sticky configuration ? can you try removing this command and check if it works ?
Rajesh.
