ACE 4710 not responding
ranjith.kanisan
We have to ACE 4710 device in our network and we have facing device hung issue in our Primary ACE. We are not able to get management access or direct console access to the device when the issue is happened and also we are not able to reach the vlan interface IP or/VIP. Please find the below output we got through monitor that we are connected to the ACE.
Booting localboot(c4710ace-t1k9-mz.A5_1_2.bin)
kernel=(hd0,1)/c4710ace-t1k9-mz.A5_1_2.bin ro root=LABEL=/ auto console=ttyS0,9
600n8 quiet bigphysarea=32768
[Linux-bzImage,setup=0x1400,size=0xe75a16c]
Uncompressing linux Ok, booting the kernal.
Issue is resolved after we manually rebooted the ACE. We have collected the sh tech after the reboot.
Software version : A5 1.2
Kindly suggest what may cause this issue.
Thanks in Adavance.
Ranjith
5 Replies 5
Cesar Roque
Level 4
Level 4
Hi Ranjith,
it could be a problem with the flash drive of the ACE.  Please gather a console output when the ACE is booting.
Just connect the console cable like you do to any Switch or Router and get the output from there.
Cesar R
ANS Team
--------------------- Cesar R ANS Team
We have collected the console logs while we done the reboot. Please find the below output.
------------------------------------------------ Boot log -----------------------------------------------------------------------------
ÐS ÀS        AMIBIOS(C)2005 American Megatrends, Inc.                                        BIOS Date: 08/25/09 09:37:25 Ver: 08.00.11                                      CPU : Intel(R) Pentium(R) 4 CPU 3.40GHz                                          Speed : 3.40 GHz        Broadcom NetXtreme Ethernet Boot Agent v8.1.53                                  Copyright (C) 2000-2005 Broadcom Corporation                                    All rights reserved.                                                            Press Ctrl-S to Enter Configuration Menu ...        Broadcom NetXtreme Ethernet Boot Agent v8.1.53        AMIBIOS(C)2005 American Megatrends, Inc.                                        BIOS Date: 08/25/09 09:37:25 Ver: 08.00.11                                      CPU : Intel(R) Pentium(R) 4 CPU 3.40GHz                                          Speed : 3.40 GHz        Press F2 to run Setup                                                           Press F12 for BBS POPUP                                                         DDR2 Frequency:667 MHz, ECC Support in Dual-Channel Interleaved Mode            Initializing USB Controllers .. Done.                                           6144MB OK        USB Device(s): 1 Keyboard                                                       Auto-Detecting Pri Slave...IDE Hard Disk                                        Pri Slave : 1GB CompactFlash Card  CF B612J        GRUB Loading stage2........                                                         GNU GRUB  version 0.95.1  (639K lower / 3144640K upper memory)               ***************************************************************************     * localboot(ACE_APPLIANCE_RECOVERY_IMAGE.bin)                             *     * localboot(c4710ace-t1k9-mz.A5_1_2.bin)                                  *     * localboot(c4710ace-t1k9-mz.A4_2_0.bin)                                  *     *        *     *        *     *        *     *        *     *        *     *        *     *        *     *        *     *        *     ***************************************************************************          Use the * and * keys to select which entry is highlighted.                      Press enter to boot the selected OS, 'e' to edit the                            commands before booting, or 'c' for a command-line.                          The highlighted entry will be booted automatically in 1 seconds.        kernel=(hd0,1)/c4710ace-t1k9-mz.A5_1_2.bin ro root=LABEL=/ auto console=ttyS0,9 600n8 quiet bigphysarea=32768                                                      [Linux-bzImage, setup=0x1400, size=0xe75a16c]        INIT: version 2.85 booting
b4 lspci
1 Cavium device(s) found.
Bringing up NP 0
Downloading U-Boot to NP card 0
Downloading DP image to NP card 0
Starting DP image on NP card on all cores
DP image started on NP card
Setting up dynamic memory size
Initializing Shared Memory
INIT: Entering runlevel: 3
Testing PCI path for Octeon(0)....
This may take some time, Please wait ....
PCI test loop , count 0
PCI path is ready
Starting services...
Waiting for 3 seconds to enter setup mode...
Certificate & key are up to date
Installing MySQL
groupadd: group nobody exists
useradd: user nobody exists
MySQL Installed
Installing JRE
JRE Installed
Starting sysmgr processes.. Please wait...Done!!!
IDC4-INTR-ACE-01 login: admin
Password:
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 1985-2012 by Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
We have not found any error related to flash while booting ACE.
Ranjith
Jorge Bejarano
Level 4
Level 4
Ranjith,
Can you upload a #show version and # dir core: ?
Jorge
IDC4-INTR-ACE-01/Admin# dir core:
2457  Dec 19 13:06:12 2012 SYSTEM_STATS
            Usage for core: filesystem
                     1071104 bytes total used
                   202025984 bytes free
                   203097088 bytes total
IDC4-INTR-ACE-01/Admin# sh version
Software
  loader:    Version 0.95.1
  system:    Version A5(1.2) [build 3.0(0)A5(1.2) adbuild_19:38:58-2012/01/17_/a
uto/adbure_nightly4/renumber/rel_a5_1_2_throttle/REL_3_0_0_A5_1_2]
  system image file: (hd0,1)/c4710ace-t1k9-mz.A5_1_2.bin
  Device Manager version 5.1 (0) 20111215:1009
  installed license: no feature license is installed
Hardware
  cpu info:
    Motherboard:
        number of cpu(s): 2
    Daughtercard:
        number of cpu(s): 16
  memory info:
    total: 6225528 kB, free: 4343804 kB
    shared: 0 kB, buffers: 12936 kB, cached 0 kB
  cf info:
    filesystem: /dev/hdb2
    total: 861668 kB, used: 787528 kB, available: 30368 kB
last boot reason:  Unknown
configuration register:  0x1
IDC4-INTR-ACE-01 kernel uptime is 0 days 0 hour 2 minute(s) 21 second(s)
Ranjith
Ranjith,
After the reboot, ACE did not generate any core dump and does not anything under last boot reason.
I would recommend to monitor the behavior and if the issue re-occurs, open a TAC case right away and console to try to get some outputs and take a look of the messages when the situation happens.
Hope this helps!
Jorge
