1093
ROMAN TOMASEK
Beginner
ACE 4710 SSL performance (TPS) for 2048bit keys?
Hi all,
do you have any info about the SSL performance for 2kb keys on ACE4710? There is only SSL performance for 1024b keys on ACE4710 (7500 SSL TPS) in the data sheet.:-( Thank you very much.
Roman
2 ACCEPTED SOLUTIONS
sivaksiv
Hi Roman,
There are no definitive numbers on the how much could a 4710 handle in term of SSL with 2048b keys  but it is much lower then what it would be if you were using 1024b keys. It is also based on testing, means different test scenario will produce different test result.
2048 bit keys require approximately 7 times more processing than 1024 bit keys, so the TPS rate should drop by this same factor in a well behaved system.
Siva
chrhiggi
Participant
Building on what Siva noted -
   ACE4710 does not have published numbers for higher bit keys, but its not uncommon to see about 1200-1400 TPS with 2048 bit keys under "average" scenarios.  You have to keep in mind that they way SSL works on any device, as the bit count goes up, it becomes *exponentially* more difficult to decrypt SSL.  As well, things like cipher strength and compression play a huge role in how inundated the SSL 'server' or in our case, the SSL daughter card becomes trying to handle 'normal' traffic flow. Obviously, if you are inundated at 100% cpu doing high-cipher-high bitstrength encryption, your TPS will start to suffer. Up to the CPU is spiked... you wouldn't see a difference. Hence, the range in performance.
  Last note - If you want to get the maximum out of your SSL daughter card, make sure to enable ssl reuse and session cache.  That does have a large impact on performance, but it is at the expense of security.
  There are many hits on google for benchmarking SSL and why there is such a hit on higher bit strenghts.  Example:
http://blog.exceliance.fr/2011/09/16/benchmarking_ssl_performance/
  Hope that helps!
Chris Higgins
5 REPLIES 5
sivaksiv
Hi Roman,
Siva
chrhiggi
Participant
  Hope that helps!
Chris Higgins
It's strange, because for example F5 shows the SSL performance for both keys (1024 and 2048). :-(
Roman-
  I don't know the real reason why some of the numbers are not released. However, I do know that we try to minimise arguments about performance numbers in general.  Performance is extremely subjective as every customer uses a product in different ways and they all effect performance uniquely.  If someone sold you a box that did 1k TPS and you could only do 800TPS with your traffic, you would probably feel you didn't get what you payed for.  As well, you don't generally want to under-sell yourself either.
Chris Higgins
Hi Christopher,
no problem. Thank you very much.
Roman
Content for Community-Ad
