02-21-2012 11:09 AM
I have ACE 4710 that load balance two cach flows (bluecoat), i am doing pbr on the routers to send the traffic destined to port 80 to ACE then Cach farm. After that the Cach flow will get the page from the internet via two routers. The return traffic will match another pbr on the routers with source port 80 that will send it to the ACE then CachFlow again .....then to the users.
I am not using ip-spoofing on the CachFlow for now. In the figure attached i created a VIP 0.0.0.0 0.0.0.0 port 80 on the interface on the ACE facing the routers, but the question is do i have to create another VIP 0.0.0.0 0.0.0.0 port 80 on the interface on ACE facing the Cach Flow? or just forward the traffic on the default route? What might be the default route since i have to use two routers and i cannot use hsrp?
Kindly I need some assistance
Thank you and regards,
George
access-list PERMIT_ALL line 8 extended permit ip any any
access-list CFLOW line 8 extended permit ip any any
ip name-server 8.8.8.8
ip name-server 4.2.2.2
##################################Config for Cache Cache Servers###################
probe http CISCO_WWW_PROBE
ip address 72.163.4.161
interval 2
faildetect 2
passdetect interval 2
passdetect count 5
request method head url /index.html
expect status 200 200
exit
probe http YAHOO_WWW_PROBE
ip address 87.248.112.181
interval 2
faildetect 2
passdetect count 5
exit
serverfarm host TRANSPARENT_PROXY_SF
description Transparent Proxy Farm
transparent
predictor hash url
probe CISCO_WWW_PROBE
probe YAHOO_WWW_PROBE
rserver CFLOW01
inservice
rserver CFLOW02
inservice
exit
exit
############################################# Router Cache Farm ############################
probe icmp ICMP_PROBE
description *** Probe for icmp health monitoring ***
interval 5
faildetect 2
passdetect interval 60
passdetect count 2
exit
rserver host Router01
description Connection to Sodetel Router
ip address 192.168.14.4
probe ICMP_PROBE
inservice
rserver host Router02
description Connection to IDM Router
ip address 192.168.14.5
probe ICMP_PROBE
inservice
serverfarm host Routers
transparent
predictor hash url
probe ICMP_PROBE
rserver Router01
inservice
rserver Router02
inservice
exit
exit
################################# Management################################
class-map type management match-any REMOTE_MGMT
description Allow Remote management for below protocols
8 match protocol icmp any
9 match protocol ssh source-address 172.31.13.31 255.255.255.255
10 match protocol ssh source-address 172.31.31.21 255.255.255.255
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
class REMOTE_MGMT
permit
class-map match-all CFLO2Internet
2 match virtual-address 0.0.0.0 0.0.0.0 any
class-map match-all TRANSPARENT_VIP_CM
2 match virtual-address 0.0.0.0 0.0.0.0 tcp eq www
policy-map type loadbalance first-match TRANSPARENT_LB_PM
class class-default
serverfarm TRANSPARENT_PROXY_SF backup Routers
policy-map type loadbalance first-match CFLO2Internet_LB
class class-default
serverfarm Routers
policy-map multi-match CFLO2Internet_PM
class CFLO2Internet
loadbalance vip inservice
loadbalance policy CFLO2Internet_LB
loadbalance vip icmp-reply active
connection advanced-options TCP
policy-map multi-match L3L4_PM
class TRANSPARENT_VIP_CM
loadbalance policy TRANSPARENT_LB_PM
====Interfaces======
interface vlan 11
description Interface between Routers and ACE
ip address 192.168.14.2 255.255.255.224
alias 192.168.14.1 255.255.255.224
peer ip address 192.168.14.3 255.255.255.224
no icmp-guard
access-group input PERMIT_ALL
service-policy input REMOTE_MGMT_ALLOW_POLICY
service-policy input L3L4_PM
no shutdown
interface vlan 21
description Connection to CFlow ServerFarm
ip address 192.168.12.2 255.255.255.224
alias 192.168.12.1 255.255.255.224
peer ip address 192.168.12.3 255.255.255.224
no icmp-guard
access-group input CFLOW
service-policy input CFLO2Internet_PM ------>>>> Is this necessary???
no shutdown
02-24-2012 09:50 AM
anyone?
02-27-2012 05:55 AM
Hi George,
In the topology you described, only the service-policy in the interface towards the routers is necessary. For the traffic from the caches, the ACE will just forward to the default gateway.
The only problem is, as you mentioned, that you cannot use HSRP. In that case, you can still configure two default gateways, but there is no way to predict which one the ACE will use at a given time (the way it does to select the one it will use is sending an ARP request to both gateways and using the one that replies first until the ARP entry expires)
If you need to load-balance the traffic between both routers, then yes, you would need to configure a new VIP on the cache side and load-balanced to a transparent serverfarm composed of both routers.
Daniel
