ACE Configuration Guide
atul.thapar
        I am new to ACE in our company there is ACE modules installed  on 6509 switches as VSS configured and we are running ver A4(2.3) for ACE. Please guide me some good http link to start reading about ACE.
-Atul
8 Replies 8
Hello Alex
Working in new enviornment and need to configure and confirm traffic restricted to only ssh and https, here is what I have come up with so far from reading other configs and document examples. I believe that part of the problem is the permit ip any any
interface gigabitEthernet 1/1
  description REAL SERVERS SDE
  speed 1000M
  duplex FULL
  switchport access vlan 200
  no shutdown
interface gigabitEthernet 1/2
  no shutdown
interface gigabitEthernet 1/3
  shutdown
interface gigabitEthernet 1/4
  speed 1000M
  duplex FULL
  switchport access vlan 500
  no shutdown
access-list ACL_10 line 8 extended permit ip any host 10.24.96.4
access-list ACL_10 line 16 extended permit icmp any host 10.24.96.4
access-list ACL_20 line 8 extended permit ip any any
access-list ACL_20 line 16 extended permit icmp any any
access-list ACL_30 line 8 extended permit ip any any
access-list ACL_30 line 16 extended permit icmp any any
access-list ACL_40 line 16 extended permit ip 10.24.96.64 255.255.255.224 any eq ssh
access-list ACL_40 line 16 extended permit ip 10.24.96.64 255.255.255.224 any eq https
probe icmp SERVICE_ICMP_PROBE
interval 10
passdetect interval 5
parameter-map type http cisco_avs_parametermap
  persistence-rebalance
  length-exceed continue
rserver host Arges
ip address 10.24.96.68
probe SERVICE_ICMP_PROBE
inservice
rserver host vsuiteFrontEnd-A
ip address 10.24.96.67
inservice
action-list type optimization http WEB-ACTION-LIST
  flashforward
action-list type optimization http cisco_avs_container_latency
  flashforward
action-list type optimization http cisco_avs_img_latency
  flashforward
action-list type optimization http cisco_avs_obj_latency
  flashforward
serverfarm host VIRTUAL-SERVER-FARM
  rserver Arges 80
    backup-rserver Brontes 80
    conn-limit max 4000000 min 4000000
    inservice
  rserver Brontes 80
    inservice
serverfarm host rule-vsuiteFrontEnd-A
rserver vsuiteFrontEnd-A
   inservice
serverfarm host rule-vsuiteSsh-A
rserver ssh-vsuiteA 22
   inservice
parameter-map type http CASE_PARAM
case-insensitive
parameter-map type connection rule-vsuiteFrontEnd-A_CONN_PARAM
set timeout inactivity 6400
parameter-map type connection rule-vsuiteSsh-A_CONN_PARAM
class-map match-any SERVERSOURCED
2 match access-list ACL_40
class-map match-all rule-vsuiteFrontEnd-A_CLASS
2 match virtual-address 10.24.96.4 tcp eq https
class-map match-all rule-vsuiteSsh-A_CLASS
2 match virtual-address 10.24.96.4 tcp eq 22
class-map type http loadbalance match-all cisco_avs_container_latency  ??????
  2 match http url http://10.10.10.*/browser/*
class-map type http loadbalance match-any cisco_avs_img_latency
  2 match http url .*jpg
  3 match http url .*jpeg
  4 match http url .*jpe
  5 match http url .*png
  6 match http url .*aspx
  7 match http url .*aspd
  8 match http url .*axd
  9 match http url .*axs
  10 match http url .i*
class-map type http loadbalance match-any cisco_avs_obj_latency
  2 match http url .*gif
  3 match http url .*css
  4 match http url .*js
  5 match http url .*class
  6 match http url .*jar
  7 match http url .*cab
  8 match http url .*txt
  9 match http url .*ps
  10 match http url .*vbs
  11 match http url .*xsl
  12 match http url .*xml
  13 match http url .*pdf
  14 match http url .*swf
  15 match http url .*aspx
  16 match http url .*aspd
  17 match http url .*axd
  18 match http url .*axs
  19 match http url .*
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol  any
  4 match protocol icmp any
  5 match protocol telnet any
  6 match protocol ssh any
  7 match protocol http any
  8 match protocol https any
  9 match protocol snmp any
policy-map type loadbalance first-match rule-vsuiteFrontEnd-A_POLICY
class class-default
   serverfarm rule-vsuiteFrontEnd-A
policy-map type loadbalance first-match rule-vsuiteSsh-A_POLICY
class class-default
   serverfarm rule-vsuiteSsh-A
policy-map multi-match POLICY
class rule-vsuiteFrontEnd-A_CLASS
   loadbalance vip inservice
   loadbalance policy rule-vsuiteFrontEnd-A_POLICY
   loadbalance vip icmp-reply active
   connection advanced-options rule-vsuiteFrontEnd-A_CONN_PARAM
class rule-vsuiteSsh-A_CLASS
   loadbalance policy rule-vsuiteSsh-A_POLICY
   connection advanced-options rule-vsuiteSsh-A_CONN_PARAM
policy-map multi-match SERVERSOURCED
class SERVERSOURCED
   nat dynamic 1 vlan 500
policy-map type optimization http first-match VIRTUAL-SERVER-20-l7opt
  class cisco_avs_obj_latency
    action cisco_avs_obj_latency
  class cisco_avs_img_latency
    action cisco_avs_img_latency
  class cisco_avs_container_latency
    action cisco_avs_container_latency
policy-map multi-match int500
  class VIRTUAL-SERVER-20
    loadbalance policy VIRTUAL-SERVER-20-l7slb
    optimize http policy VIRTUAL-SERVER-20-l7opt
    appl-parameter http advanced-options cisco_avs_parametermap
  class VIRTUAL-SERVER-11
    loadbalance policy VIRTUAL-SERVER-11-l7slb
interface vlan 200
  description "REAL SERVERS"
  ip address 162.16.103.1 255.255.255.0
  service-policy input remote_mgmt_allow_policy
  no shutdown
interface vlan 500
  description ACE CLIENT VLANE_Client VLAN
  ip address 10.10.10.5 255.255.255.0
  access-group input ALL
  service-policy input int500
  no shutdown
interface vlan 820
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.10.10.1
snmp-server contact "CHARLES"
snmp-server location "DEP"
snmp-server community DEP group Network-Monitor
snmp-server trap-source vlan 820
Hi Charles,
If you are talking about management traffic you need a configuration like this:
class-map type management match-any NSS-MGT
   3 match protocol https any
policy-map type management first-match MGT
  class NSS-MGT
    permit
interface vlan 144
  ip address 10.198.44.11 255.255.255.0
  peer ip address 10.198.44.15 255.255.255.0
  service-policy input MGT
  no shutdown
If you want to restric even more and specify the IP address that are going to be permitted you can configure the policy like this:
   3 match protocol https source x.x.x.x z.z.z.z
   6 match protocol ssh  source x.x.x.x z.z.z.z
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hello Cesar
I greatly appreciate your response and will give this a go, then reply if I need further help.
Thank you
It appears that ssh is not for management but for sending data to us.
I can not get rservers up or the VIPs active.... Help Me....
logging enable
logging timestamp
logging trap 5
logging history 5
logging buffered 6
logging persistent 5
logging monitor 5
logging queue 5000
boot system image:c4710ace-t1k9-mz.A5_1_2.bin
hostname x86ACE03
switchport access vlan 700
no shutdown
switchport trunk allowed vlan 701,704
no shutdown
shutdown
shutdown
ntp server 157.127.103.139
access-list ACL_10 line 8 extended permit ip any host 10.22.6.117
access-list ACL_10 line 16 extended permit icmp any host 10.22.6.117
access-list ACL_10 line 24 extended permit ip any host 10.22.6.116
access-list ACL_10 line 32 extended permit icmp any host 10.22.6.116
access-list ACL_10 line 34 extended permit icmp any host 10.22.6.118
access-list ACL_10 line 38 extended permit ip any host 10.22.6.118
access-list ACL_10 line 40 extended permit ip any host 10.22.6.119
access-list ACL_10 line 48 extended permit icmp any host 10.22.6.119
access-list ACL_40 line 16 extended permit ip 10.22.7.2 255.255.255.224 any
access-list ACL_50 line 16 extended permit ip 10.22.7.34 255.255.255.224 any
access-list FILTER line 10 extended permit tcp any any eq https
access-list FILTER line 20 extended permit tcp any any eq www
interval 10
ip address 10.22.6.116 ! 10.22.7.2
inservice
rserver host vsuiteFrontEnd-CoreA
ip address 10.22.6.118  ! 10.22.7.34
inservice
   conn-limit max 4000000 min 1
   inservice
serverfarm host rule-vsuiteFrontEnd-CoreA
rserver vsuiteFrontEnd-CoreA
   inservice
case-insensitive
parameter-map type connection rule-vsuiteFrontEnd-CoreA_CONN_PARAM
class-map type management match-any REMOTE_ACCESS_CLASS
description Enable remote management
class-map match-any SERVERSOURCED-CoreA
2 match access-list ACL_50
2 match virtual-address 10.22.6.117 tcp eq https
class-map match-all rule-vsuiteFrontEnd-CoreA_CLASS
2 match virtual-address 10.22.6.119 tcp eq https
policy-map type management first-match REMOTE_ACCESS_POLICY
class REMOTE_ACCESS_CLASS
   permit
class class-default
policy-map type loadbalance first-match rule-vsuiteFrontEnd-CoreA_POLICY
class class-default
   serverfarm rule-vsuiteFrontEnd-CoreA
policy-map multi-match POLICY-CoreA
class rule-vsuiteFrontEnd-CoreA_CLASS
   loadbalance policy rule-vsuiteFrontEnd-CoreA_POLICY
   connection advanced-options rule-vsuiteFrontEnd-CoreA_CONN_PARAM
class SERVERSOURCED
   nat dynamic 1 vlan 700
policy-map multi-match SERVERSOURCED-CoreA
class SERVERSOURCED-CoreA
   nat dynamic 2 vlan 700
service-policy input POLICY
service-policy input POLICY-CoreA
interface vlan 700
ip address 10.22.6.2 255.255.255.224
no icmp-guard
access-group input ACL_10
nat-pool 1 10.22.6.117 10.22.6.117 netmask 255.255.255.255 pat
nat-pool 2 10.22.6.119 10.22.6.119 netmask 255.255.255.255 pat
service-policy input REMOTE_ACCESS_POLICY
no shutdown
interface vlan 701
ip address 10.22.7.2 255.255.255.224
no icmp-guard
access-group input ACL_20
service-policy input SERVERSOURCED
no shutdown
interface vlan 704
ip address 10.22.7.34 255.255.255.224
no icmp-guard
service-policy input SERVERSOURCED-CoreA
no shutdown
ip route 0.0.0.0 0.0.0.0 10.22.6.1
x86ACE03/Admin#
x86ACE03/Admin# sh probe
probe       : SERVICE_ICMP_PROBE
type       : ICMP
state       : ACTIVE
   port     : 0          address   : 0.0.0.0
   addr type : -           interval : 10     pass intvl : 5
   pass count: 3           fail count: 3       recv timeout: 10
               ------------------ probe results ------------------
   associations     ip-address         port porttype probes failed passed health
   rserver     : vsuiteFrontEnd-A
                           10.22.6.116   0 --     78   78     0     FAILED
   rserver     : vsuiteFrontEnd-CoreA
                           10.22.6.118   0 --     459   459   0     FAILED
x86ACE03/Admin#
x86ACE03/Admin# sh service-policy
Policy-map : POLICY
Status     : ACTIVE
Context Global Policy:
service-policy: POLICY
   class: rule-vsuiteFrontEnd-A_CLASS
     loadbalance:
       L7 loadbalance policy: rule-vsuiteFrontEnd-A_POLICY
       VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
       VIP state: OUTOFSERVICE
       VIP DWS state: DWS_DISABLED
       Persistence Rebalance: DISABLED
       curr conns       : 0         , hit count       : 0
       dropped conns   : 0
       conns per second   : 0
       client pkt count : 0         , client byte count: 0
       server pkt count : 0         , server byte count: 0
       conn-rate-limit     : -         , drop-count : -
       bandwidth-rate-limit : -         , drop-count : -
     compression:
       bytes_in : 0                         bytes_out : 0
       Compression ratio : 0.00%
               Gzip: 0               Deflate: 0
     compression errors:
       User-Agent : 0               Accept-Encoding   : 0
       Content size: 0               Content type       : 0
       Not HTTP 1.1: 0              HTTP response error: 0
       Others     : 0
       Parameter-map(s):
Policy-map : POLICY-CoreA
Status     : ACTIVE
service-policy: POLICY-CoreA
   class: rule-vsuiteFrontEnd-CoreA_CLASS
     loadbalance:
       L7 loadbalance policy: rule-vsuiteFrontEnd-CoreA_POLICY
       dropped conns   : 0
     compression:
               Gzip: 0               Deflate: 0
     compression errors:
       Others     : 0
       Parameter-map(s):
Policy-map : SERVERSOURCED
Status     : ACTIVE
Interface: vlan 1 701
service-policy: SERVERSOURCED
   class: SERVERSOURCED
     nat:
       dropped conns   : 0
       conn-rate-limit     : 0         , drop-count : 0
       bandwidth-rate-limit : 0         , drop-count : 0
Policy-map : SERVERSOURCED-CoreA
Status     : ACTIVE
Interface: vlan 1 704
service-policy: SERVERSOURCED-CoreA
   class: SERVERSOURCED-CoreA
     nat:
       dropped conns   : 0
x86ACE03/Admin# sh serverfarm
   serverfarm           type     rservers predictor         current conns
                       HOST     1       ROUNDROBIN         0
                       HOST     1       ROUNDROBIN         0
x86ACE03/Admin# sh serverfarm rule-vsuiteFrontEnd-A
serverfarm     : rule-vsuiteFrontEnd-A, type: HOST
total rservers : 1
state         : INACTIVE
DWS state     : DISABLED
                                               ----------connections-----------
       real                 weight state       current   total     failures
   rserver: vsuiteFrontEnd-A
       10.22.6.116:0         8   PROBE-FAILED   0         0         0
total rservers : 1
state         : INACTIVE
x86ACE03/Admin#
atul.thapar
Thanks Alex and Jorge,
I have to configure ACE for Riverbed and our ACE is on blade in 6509 and 6509 is in VSS. ACE is configured in context. Can any one please help, I know its small thing for you guys but big for me as new to ACE.
-Atul
