ACE Load balancing with different source IP
sansarav720e
  Dear All ,
             I am very much new to ACE . We are deploying it on our enterprise infrastructure (10.x.x.x/8) . I have a setup like this, we have 5 Proxy server which is supporting for our enteprise internet needs . Load balancing to this 5 blue coat proxy server is done via ACE module .
  My customer is having special requirement based on specfic source subnet , ACE need to redirect the that specific source subnet to a particular proxy server . Is this possible in ACE ?? or we need to have separate Virtual server group for that specific source subnet range  . kindly correct me if am worng on my understanding .
Santhoshkumar Saravanan
HTH Regards Santhosh Saravanan
2 Accepted Solutions
gaursin2
I guess stsickiness is answer to your problem. Try static source base stickiness and point individual subnet to specific proxy.
Hi Saravanan,
Please refer the following link :
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_2_0/configuration/slb/guide/sticky.pdf
Look at section :
IP Address Stickiness Configuration Quick Start
For example :
8. (Optional) Configure static IP address sticky entries up to a maximum of
65535 static entries per context.
host1/Admin(config-sticky-ip)# static client source 192.168.12.15
destination 172.16.27.3 rserver SERVER1 2000
The above may fulfill your requirement.
regards,
Ajay Kumar
gaursin2
Dear Gaurav,
                Thanks for your response , I am new to ACE can i have some sample example or document to have more understanding on this topic .Thank you ..
Hi Saravanan,
Look at section :
For example :
regards,
Ajay Kumar
Dear Ajay & Gaurav
           Thanks much for your response & apprecitated .
