ACE module - get bandwidth per VIP
luis.repas
Hi all,
On the ace module, the bandwidth per VIP is a piece of information one can easily get on the cli,
as the below output shows.
sh service-policy VIP_EXAMPLE
Status     : ACTIVE
Context Global Policy:
   service-policy: VIP_EXAMPLE
     class: VIP_CLASS
       loadbalance:
         L7 loadbalance policy: VIP-EXAMPLE-POLICY
         VIP Route Metric     : 77
         VIP Route Advertise  : DISABLED
         VIP ICMP Reply       : ENABLED
         VIP State: INSERVICE
         curr conns       : 4         , hit count        : 1414008981
         dropped conns    : 6586
         client pkt count : 2999321062, client byte count:  1124716083840
         server pkt count : 2992929531, server byte count:  1382599949591
         conn-rate-limit      : 0         , drop-count : 0
         bandwidth-rate-limit : 0         , drop-count : 0
I would like to know if this information is also available via SNMP as it is the case for  the connection number and connections rate per VIP.
litrenta
Level 3
Level 3
That particular info is not currently implemented in an snmp oid. The only way you would be able
to get it into an application would be to do the query using an xml api call
thanks for your reply.
Luis Repas
