ACE module only inserting X-Forwarder Header on first packet
scott-goodwin
As above, I have a strange problem where if I use my proxy server to access an LB VIP then it is inserting the X-forwarding header for Each GET request.
However if I make the request direct from my PC (not via Proxy) it inserts the header on the first packet but no subsequent packets unless I restart the browser.
Any ideas????
Scott
Sean Merrow
Level 4
Level 4
Hi Scott,
In the ACE documentation, check out the section on Configuring the ACE to Modify Headers on Every HTTP Request or Response.
I hope this helps,
Sean
Sean Merrow
Level 4
Level 4
Hi Scott,
I hope this helps,
Sean
Thanks Sean, that has cured our initial problem in the test enviroment, just rolling it out to live network so fingers crossed
Scott
