03-31-2009 08:03 AM
Greetings:
I have an ACE module that is load balancing a pair of AVS 3120 devices. I want to create a probe to monitor the AVS devices to remove them if they fail to perform. Does anyone have a recommendation of the best practice for the probe design? Currently I am monitoring the AVS devices on port 80 but I do not know if âport 80 is aliveâ is the best way to check these devices. Any recommendations on AVS monitoring is greatly appreciated.
04-07-2009 06:08 AM
Not sure if you've seen this link but it might help...
04-07-2009 06:23 AM
I had not seen that link. Thank you for your input. The document mentions cisco_avs_parametermap, I will need to research this setting to see if it applies to the external AVS devices.
