ACE VIP not Responding to Ping and cant Connect
ayojosh2k
Hello All,
I recently deployed an ACE 4710 Appliance. Configs seems right but clients cant Ping the VIP and acnt also connect to the VIP. Also VIP Dosent show in 'sh arp'.
Pls HELP!!!
See the configs!!
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.10.11 10:48:14 =~=~=~=~=~=~=~=~=~=~=~=
sh runGenerating configuration....
boot system image:c4710ace-mz.A4_2_0.bin
hostname STERLING-ACE
interface gigabitEthernet 1/1
  channel-group 1
  no shutdown
interface gigabitEthernet 1/2
  channel-group 1
  no shutdown
interface gigabitEthernet 1/3
  channel-group 1
  no shutdown
interface gigabitEthernet 1/4
  channel-group 1
  no shutdown
interface port-channel 1
  switchport trunk allowed vlan 10,200,205,210,215
  no shutdown
--More--
access-list INBOUND line 10 extended permit ip any any
access-list INBOUND line 16 extended permit icmp any any
access-list INBOUND line 24 extended permit icmp any any echo
probe http BANK-APP
  interval 2
  faildetect 2
  passdetect interval 2
  expect status 200 200
  open 1
probe icmp PING
  description ***simple ping monitor***
  interval 10
  passdetect interval 60
  passdetect count 2
  receive 1
probe tcp TCP80
  interval 10
  passdetect interval 10
  passdetect count 2
--More--
  receive 1
  open 5
rserver host BANK-APP-SERVER1
  description ***GUI SERVER 1***
  ip address 172.20.1.50
  probe PING
  inservice
rserver host BANK-APP-SERVER2
  description ***GUI SERVER 2***
  ip address 172.20.1.51
  probe PING
  inservice
rserver host BANK-APP-SERVER3
  description ***GUI SERVER 3***
  ip address 172.20.1.52
  probe PING
  inservice
rserver host BANK-APP-SERVER4
  description ***GUI SERVER 4***
  ip address 172.20.1.53
  probe PING
--More--
  inservice
rserver host THIN-CLIENT1
  description ***CLI SERVER 1***
  ip address 172.20.1.34
  probe PING
  inservice
rserver host THIN-CLIENT2
  description ***CLI SERVER 2***
  ip address 172.20.1.35
  probe PING
  inservice
rserver host THIN-CLIENT3
  description ***CLI SERVER 3***
  ip address 172.20.1.36
  probe PING
  inservice
rserver host THIN-CLIENT4
  description ***CLI SERVER 4***
  ip address 172.20.1.37
  probe PING
  inservice
--More--
serverfarm host CLI-GROUP
  predictor leastconns
  probe TCP80
  rserver THIN-CLIENT1
    inservice
  rserver THIN-CLIENT2
    inservice
  rserver THIN-CLIENT3
    inservice
  rserver THIN-CLIENT4
    inservice
serverfarm host GUI-GROUP
  probe TCP80
  rserver BANK-APP-SERVER1
    inservice
  rserver BANK-APP-SERVER2
    inservice
  rserver BANK-APP-SERVER3
    inservice
  rserver BANK-APP-SERVER4
    inservice
--More--
parameter-map type connection TCP-PARAM-MAP
  set timeout inactivity 360000
class-map type management match-any REMOTEACCESS
  description remote access traffic match
  2 match protocol ssh any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol xml-https any
  6 match protocol http any
  7 match protocol https any
class-map match-all TCP-CLASS
  description TCP CONNECTION TIMER
  2 match any
class-map match-all VS_WEB1
  2 match virtual-address 10.0.0.115 any
class-map match-all VS_WEB2
  2 match virtual-address 10.0.0.113 any
policy-map type management first-match REMOTEPOLICY
--More--
  class REMOTEACCESS
    permit
policy-map type loadbalance first-match HTTP_LB1
  class class-default
    serverfarm CLI-GROUP
policy-map type loadbalance first-match HTTP_LB2
  class class-default
    serverfarm GUI-GROUP
policy-map multi-match HTTP_MULTI_MATCH1
  class VS_WEB1
    loadbalance vip inservice
    loadbalance policy HTTP_LB1
    loadbalance vip icmp-reply
policy-map multi-match HTTP_MULTI_MATCH2
  class VS_WEB2
    loadbalance policy HTTP_LB2
policy-map multi-match TCPIP-POLICY
  class TCP-CLASS
connection advanced-options TCP-PARAM-MAP
service-policy input REMOTEPOLICY
service-policy input TCPIP-POLICY
interface vlan 10
  description ***LAN LEG***
  ip address 10.0.0.66 255.255.255.0
  no icmp-guard
  access-group input INBOUND
  no shutdown
interface vlan 200
  description ***THIN CLIENT VLAN****
  ip address 172.20.1.33 255.255.255.240
  no icmp-guard
  service-policy input HTTP_MULTI_MATCH1
  no shutdown
interface vlan 210
  description ***BANK APP SERVER VLAN****
  ip address 172.20.1.49 255.255.255.240
  no icmp-guard
--More--
  service-policy input HTTP_MULTI_MATCH2
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.0.0.200
username admin password 5 $1$ouG5.Okh$jwBoWkMiWstoTPwb9K9ku1  role Admin domain
default-domain
username www password 5 $1$M31zwdiF$iY8Y5e9nV2sMM2HxwrQI7/  role Admin domain de
fault-domain
STERLING-ACE/Admin#
Thanks!!
Hi Joshua,
You have  applied
"service-policy input HTTP_MULTI_MATCH1"  in VLAN 200 and 210 but as per the config I believe it should be applied to VLAN10.
interface vlan 10
  no icmp-guard
  no shutdown
Can you apply the service policy in VLAN 10 and let me know the result.
8 Replies 8
ajayku2
First check if the packets are reaching ACE VIP or not.
You can start with the packet capture on ACE itself
To start the packet capture function for CAPTURE1, enter:
host1/Admin# capture CAPTURE1 interface vlan50 access-list ACL1
host1/Admin# capture CAPTURE1 start
host1/Admin# capture CAPTURE1 stop
host1/Admin# show capture capture1
Hello Ajay
Thanks for the response, but it is established that traffic can reach the ACE cos i can ping the real IPs of the servers behind the ACE from the client's side, Also VIP status is 'inservice', VIP icmp-reply is activated, Server farm is Operational...
But i cant still ping the VIP from the client's side and i cant connect to the VIP
Oping for your response....
Hi Joshua,
You have  applied
interface vlan 10
  no icmp-guard
  no shutdown
Hello Ajay
Thanks for your response, i did this and it worked fine.
But i still have one more concern. The serverfarm on vlan 210 needs to acces a database server on vlan 10, but connection is truncated. Do i need to use NAT here?
Thanking you...
Hi joshua,
If you point the default gateway on all the server to their respective VLAN interface IP. They should ideally be reachable without any further configuration.
Only in case if you are not pointing the default gateway to ACE the issue may arise. Also make sure access list to allow the traffic is applied on all the VLAN.
Hello Ajay
Thanks for the support soo far. Everything is working fine now, but there is now a strange requirement:
The loadbalanced servers are actually Application servers that connects to A database server for it to function. But in a case where one of the application servers cannot connect to the DB server, ACE still forwards connction request to that server since the TCP probe to port 23 is still responding.
My Question: is it possible to set a probe to inactivate an application server as soon as it cannot connect to the DB server?
Thanks for the anticipated response!!!!!
Hi Joshua,
Simple solution would be to probe the database server instead of application server But that will not detect failure of application server.
The best design recommendation would be to create another VIP loadbalancing database servers.
That way all the application server will point the database server as the "databaseVIP". In case of failure of one of the database server the request will go to another DATABASE server.
I believe this is usually what design suggest.
Hi Joshua,
It is recommended that you apply the service-policy on an interface where your client traffic is hitting. I guess that's what is missing.
_
Siva
