CE-590 and external SCSI (no Cisco)
awo
It is possible to connect and run correctly other than "six-drive Cisco Storage Array" device to external SCSI port on CE-590 device ?
I'm asking becouse of problems with ordering SA6-SHF-6DISK-AC...
Anybody tried doing it ? Which manufacturer is OEMend under SA6 ?
Gilles Dufour
I know some peolpe have tested this in the lab and it worked most of the time.
However, this is not a supported solution by Cisco, so if you do this and run into any trouble, you won't get support.
Gilles.
