We have one Cisco ACE in our data center which is working fine but has Amber light on front & Rear.
I read the document & it shows that either it is a system fault or internal fan failure.
I am sure it is a fan failure because if there was any system fault then ACE dont work properly.
Could any one face the same issue & what is the resolution for this?
should we replace the hardware?
unfortunatley we dont have support contract & i am working to get it one.
Thanks.
Yasir
