1057
Cisco c3750X can use WCCP mask value with weight or not
Hello
We're setting up an scenario with 2 Proxy using WCCP to distribute the load.
The switches are catalyst 3750X so we're using redirect in. L2 redirection and mask to optimize forwarding of redirected packet.
I would like to know can we use mask value with weight in Switch 3750X ?
It's possible?
Regards, Nuthapon
2 REPLIES 2
balaji.bandi
VIP Master
Not sure what is the version of Code, as i remember when i did some test it did not have capabilities (this was very old 5-06 years or more back in days) - things might have changed with 15.X  code,
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_44_se/configuration/guide/scg/swwccp.html
BB
How to Ask The Community for Help
Thanks for your information. I already tested C3750X running version 152-4.E10 with WCCP with L2 redirection and mask I found that when the proxy set weight. Then, the switch cannot use weight for optimize forwarding of redirected packet.
Note: I don't see/ nor recommend using mask value with weight in cisco guild
