Highlighted
Beginner
Combining layer 3/4 and layer 7 filtering
Hi.
The configuration below is extracted from a working configuration where the ACE is doing SSL offload for a web service - this is pretty standard stuff.
What I have been asked to do is modify the configuration so that:
1) Any connections from an internal source (this will be the 10.0.0/8 and 17.16.0.0/16 range of IP's) can continue to access any URL.
2) Any other connections - which will be from an external source - are only allowed to access URL's beginning with /public and /downloads.
Can you please advise me on how to change this?  If necessary, I can define a second VIP for the external connections and setup the DNS appropriately.
Thanks in advance
___________________________________________
crypto chaingroup WEBSERVER_CHAIN
  cert WEBSERVER.CER
  cert VERISIGN.CER
probe tcp WEBSERVER
  port 7777
ssl-proxy service SSL_PROXY_WEBSERVER
  key WEBSERVER.KEY
  cert WEBSERVER.CER
serverfarm host WEBSERVER
  probe WEBSERVER
  rserver SERVER1 7777
    inservice
  rserver SERVER2 7777
    inservice
sticky http-cookie WEBSERVER_COOKIE WEBSERVER_StickyGroup
  cookie insert browser-expire
  replicate sticky
  serverfarm WEBSERVER
class-map match-all WEBSERVER
  10 match virtual-address 172.16.16.1 tcp eq https
policy-map type loadbalance first-match WEBSERVER_L7
  class class-default
    sticky-serverfarm WEBSERVER_StickyGroup
policy-map multi-match GlobalLB
class WEBSERVER
    loadbalance vip inservice
    loadbalance policy WEBSERVER_L7
    loadbalance vip icmp-reply
    ssl-proxy server SSL_PROXY_WEBSERVER
2 REPLIES 2
Participant
Re: Combining layer 3/4 and layer 7 filtering
first make class maps to characterize the traffic:
class-map type http loadbalance match-all ten
  2 match source-address 10.0.0.0 255.0.0.0
  4 match http url .*
class-map type http loadbalance match-all seventeen
  2 match source-address 17.16.0.0 255.255.0.0
  4 match http url .*
class-map type http loadbalance match-any restrict
  2 match http url /public.*
  4 match http url /downloads.*
then use in load balance policy as follows:
class ten
class seventeen
class restrict
if you want to send outside users with other urls to a sorry page you would have a server in a serverfarm taht would do that and use it in a class class-default on the bottom of the load balance policy. The matches on load balance policy are top down so order is important.
Participant
As usual your posts are informative litrenta
Content for Community-Ad
August's Community Spotlight Awards
