Compression question for the SSL-C module on CSS
jason.espino
Does anybody know what the newline format file type the the SSL-C module supports? I have a .js file and if I set the newline format of the source file to windows the CSS displays/delivers the last portion of the file. The moment I change the newline format of the source file to UNIX the problem goes away.
Also, if I convert all the tabs in the file to spaces (while still using windows newlines), the problem goes away as well.
Can someone please provide some insight?
Gilles Dufour
Weird.
The newline format should have no impact.
This seems like a bug.
Have you tried the latest version ?
If yes, open a service request with the TAC for follow up.
Gilles.
Hello Gilles,
It turned out to be a code related issue on the CSS. Upgrading the firmware resolved the issue.
Thanks you for your input though!
