Critical Alarm with CM after uprgade
Zubair.Sayed_2
Beginner
Beginner
Hi All.
I upgraded my CM using the copy ftp install command and reloaded CM and all worked fine.
I now noticed the following Critical alarm appears on the CM device:
"Central Manager's secure store is initialized but not opened"
Zubair
Hi Zubai,
When you reboot the Central Manager, you must re-enable secure store encryption manually. Disk encryption and CIFS preposition features on the remote WAE devices will not operate properly until you enter the secure store password on the Central Manager to re-enable secure store encryption.
Please refer to the following document for more detail about re-initializing the secure store:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v413/configuration/guide/other.html#wp1053890
Best regards,
Ahmad
