CSM serverfarm has reached configured max-conns
jimmyhe82
Recently, one of our soon to be deployed serverfarm stopped responding to requests, because it has reached the max-conn limit.
The strange thing is, the serverfarm is usually under very little load.
Here are some dumps of the CLI
CSM01#sh mod csm 7 vservers name ipc2.web.http config
IPC2.WEB.HTTP, type = SLB, state = OPERATIONAL, v_index = 64
virtual = 20.254.127.24/32:81 bidir, TCP, service = NONE, advertise = FALSE
idle = 3600, replicate csrp = connection, vlan = 801, pending = 30, layer 4
max parse len = 2000, persist rebalance = TRUE
ssl sticky offset = 0, length = 32
conns = 1, total conns = 76532
maxconn drops = 0, total drops = 242
Policy <default>
serverfarm IPC2.WEB.HTTP, type = SLB, predictor = Src IP
Description:
nat = SERVER
bind id = 0, fail action = none
inband health config: <none>
retcode map = <none>
Probes:
PORT-80, type = tcp
Real servers:
20.254.52.4:80, weight = 8, OPERATIONAL
20.254.52.6:80, weight = 8, OPERATIONAL
20.254.52.5:80, weight = 8, MAXCONNS
CSM01#sh mod csm 7 server name ipc2.web.http detai
Description:
nat = SERVER
virtuals inservice = 2, reals = 3, bind id = 0, fail action = none
Probes:
PORT-80, type = tcp
Real servers:
20.254.52.4:80, weight = 8, OPERATIONAL, conns = 0
20.254.52.6:80, weight = 8, OPERATIONAL, conns = 4294967295
20.254.52.5:80, weight = 8, MAXCONNS, conns = 4294967294
Total connections = 4294967293
CSM01#sh mod csm 7 conns vserver ipc2.web.http detail
prot vlan source destination state
As you can see, the counter has maxed out, even thoguh the connections table is blank.
Any help is much appreciated.
Jim
Gilles Dufour
what CSM version ?
Looks like the counter wrapped around. That is, you had 0 connections and for some reason the counter was decremented by one, which gave the huge number of connections.
Definitely a bug, but will need to know the config, the version, and if possible information about the tests that have been done prio to be in this state.
Gilles.
