CSM - show run module # - diagnostic not supported
Hi, I´d like to know why show run module # (where is CSM) doesn´t show anything that I´ve configured before. I have CSM 3.1(5) and IOS 12.1(19)E1 with SUP2 MSFC2. Is this supported or a Bug ?
I also would like to know if it´s normal to appear not supported CSM module (6) when I use the command show module. This is because I can use CSM without problems. Is this supported or a Bug ?
Router#show module
Mod Online Diag Status
1 Pass
3 Pass
4 Pass
6 Not Supported
Thank you !!
only supported in SX version.
Gilles.
jfoerster
Level 4
Level 4
online diagnostics are not supported for CSM as far as I know. Have you ever configured the CSM? What appears if you do a sh run?
Joerg
Hi Joerg,
There´s no problem with show run if you want to see CSM configuration, but if you use IOS 12.2(14)SX1 with SUP720 you can use the command show run module # (where is CSM) and appears what you want.
I ´d like to know if this command is not supported with SUP2 and IOS 12.1(19)E1 or if it is a cosmetic Bug. I was searching in the Bug Toolkit and Release Notes and I didn´t find anything about it.
Could you give me a link where I can see "online diagnostics are not supported for CSM" ?.
Thank you.
Gilles.
