CSS 11503 keepalive scripts
tomesmyth
Community Member
Is it possible to configure a keepalive script to detect the text returned from a cold fusion web page - eg "server available". Not the header but actual content of the page.
17 Replies 17
as shown in the script, you need to provide 3 arguments:
set HostName “${ARGS}[1]”
set WebPage “${ARGS}[2]”
set HostTag “${ARGS}[3]”
1 - ip address or hostname which will be used as destination to open the connection
2 - url ie: /index.html
3 - server hostname: ie www.cisco.com
You can pass the info to the script with the keepalive command.
CSS11503-2(config-service[linux1])# keepalive type script ap-kal-httptag ?
Script Arguments (Len: 0-128)
Or you can put the information inside the script iself.
Gilles.
OK Gilles, I understand the part of the 3 arguments, but based on my configuration and the parameters I'm using this will be ?
keepalive type script ap-kal-httptagban "192.168.249.3 /bancasa/start.swe?SWECmd=Logoff www2.bhd.com.do"
is this command ok ?
Do you see anything wrong with my script and the fact that this is an ssl back-end ?
How and where on the script I will define these arguments if I were to configure it in the script itself ?
Pardon my ingnorance, I'm new to CSS and scripts.
Thank
