Flow timeout on Cisco CSS 11503
casablancag
I have 2 Cisco CSS 11503 Version 7.30.05 with no content Services configured on it. At this moment the CSS works as a router. Now I see that a flow is tear down after about 15 sec. I guess that this is caused by the flow timeout. I implemented the flow permantent command but without positive results. Any suggestions ???
Gilles Dufour
the CSS 1150x can change the timeout only for flow matching a content rule.
The flow permanent should work [stop timing out flows] but is very dangerous as resources are never freed anymore and you will for sure end up with a device unable to switch new flows.
So, I would strongle recommend not to use this device as a router as it is not.
Gilles.
