01-30-2012 09:10 AM
I first tried to back it up through the CM, but was getting errors in regards to the it failing while setting the remote directory. So i Putty'ed onto the individual wave and typed in the following:
copy ftp virtual-blade 1 disk 1 192.x.x.x(ftp server) / bladename.img
and it came back with:
This will delete the existing disk image.
Are you sure you want to proceed?
I just want to make sure that this will not delete the blade that I am trying to back up???
Solved! Go to Solution.
01-31-2012 12:47 AM
Hi Dan,
You are using the wrong syntax. With this command, what you are trying to do is copying a file from a FTP server into a virtual-blade disk. That's why it's asking you whether you want to overwrite the data.
The right command to use to make a backup is "copy virtual-blade 1 disk 1 ftp 192.x.x.x(ftp server) / bladename.img"
I hope this helps
Daniel
01-31-2012 12:47 AM
Hi Dan,
I hope this helps
Daniel
