GSS-4480 : SSL Certificate problem
yves.haemmerli
When I first configured my GSS, a certificate has been automatically created by the GSS for the https GUI access. Then, I wanted to reconfigure the box from scratch with another hostname (the GSS database has been deleted as well).
After reconfiguration, I noticed that the SSL server certificate is still refering to the old hostname.
What is the procedure to change the GSS certificate for SSL to refer to the new hostname ?
PS: In the directory /cisco/merlot/safe-state, I found the files web.crt and web.key, but they cannot be deleted as the file system is read-only
Thank you
Yves
Gilles Dufour
I think you will have to use the command :
restore-factory-defaults
Gilles.
