Inline interface problems after upgrade to 4.1.3b
ruben.montes
after the upgrade, I have the following output:
WAE#sh interface inlinegroup 1/0
Interface is in intercept operating mode.
Standard NIC mode is off.
Disable bypass mode is off.
VLAN IDs configured for inline interception: All
Watchdog timer is enabled.
Timer frequency: 1600 ms.
Autoreset frequency 500 ms.
The watchdog timer will expire in 1338 ms.
Inline Port Statistics Of The Group:
WAN Port :
Device name : eth4. Bypass master interface.
Packets Received : 0
Packets Intercepted: 0
Packets Bridged : 0
Packets Forwarded : 0
Packets Dropped : 0
Packets Received on native : 0
Active flows for this interface : 0
Ethernet Driver Status
Type:Ethernet
Ethernet address:00:E0:ED:0C:A0:14
Maximum Transfer Unit Size:1500
Metric:1
Packets Received: 0
Input Errors: 0
Input Packets Dropped: 0
Input Packets Overruns: 0
Input Packets Frames: 0
Packet Sent: 0
Output Errors: 0
Output Packets Dropped: 0
Output Packets Overruns: 0
Output Packets Carrier: 0
Output Queue Length:1000
Collisions: 0
Base address:0x5080
Flags:UP BROADCAST MULTICAST
Link State: Interface is up,line protocol down
LAN Port :
Device name : eth5. Bypass slave interface.
Packets Bridged : 0
Packets Dropped : 0
Type:Ethernet
Ethernet address:00:E0:ED:0C:A0:15
Metric:1
Packets Received: 0
Input Errors: 0
Packet Sent: 0
Output Errors: 0
Collisions: 0
Base address:0x50c0
Flags:BROADCAST MULTICAST
Link State: Interface is administratively down, line protocol down
The link state of the interfaces is weird, as I have this configuration:
interface InlineGroup 1/0
inline vlan all
no autosense
bandwidth 100
full-duplex
exit
I have to say that nothing is connected, but is this output normal??
Jan Rockstedt
Why upgrade to 4.1.3b and not 4.1.5f?
Try to run sh interface inlineport 1/0/lan or sh interface inlineport 1/0/wan and see if what it showing.
Jan
Zach Seils
Level 7
Level 7
This output is normal.  The link state is propagated between the ports in the InlineGroup.  See CSCsh04752 for more information.
Zach
so, I shouldn't be worried about this?
I had other customers running 4.1.3b, that is why I chose that one. Is there any major problem with 4.1.3b?
sh interface inlineport 1/0/lan or sh interface inlineport 1/0/wan show same as above
Customer had the WAN router disconnected from WAE, and when we've tried to reconnect the WAE, there were latency and connectivity problems. Customer is sure it's a SP issue, I just wanted to be sure because this output was very strange. So, even with the WAE running fine, could I have that output due to the bug?
Ruben
No, the output you are seeing is expected.  That being said, you should upgrade to the latest 4.1.x release to avoid any other issues with your deployment.
Regarding your customer's performance issue, do they still have latency and connectivity probems when the WAE is not in-path?
Zach
