09-02-2011 02:19 AM
Hi Everyone,
I recently installed the license ACE-SSL-05K-K9 on ACE10 with multicontext solution.
The license provides 5000 Maximum number of SSL transactions per second (TPS).
The customer would like to track this to find out the correct size and in the case of services https upgrade licenses.
Can I do it so through particular output or it's necessary monitoring with snmp service? In the second case, can you tell me the oid string to use?
In case the module should receive a higher number of connections to that provided by the license, what's the issue for new https connections?
Dino
Solved! Go to Solution.
09-02-2011 03:34 AM
Hello Dino!
You can go into the Admin-Context and use sh resource usage all. Watch out for the ssl-connections rate. But I dont know the OID for this. But you can look into Cisco's MIB browser.
Cheers,
Marko
09-02-2011 03:34 AM
Hello Dino!
Cheers,
Marko
09-02-2011 03:41 AM
Hi Marko,
thank you for this helpful information. Regardig Cisco mib browser, it's not available obtain any information regarding MIB for Ace module.
Cheers,
Dino
09-02-2011 03:44 AM
Or you download the SLB-MIB and SLB-EXT-MIB for the module and look through it for anything related to conntection rate.
