10-23-2006 06:12 AM
I have recently upgraded one of our pixes from 6.3 (4) to 7.2(1) the unit is a 515UR with 128MB memory.
However since I have upgraded I have notices that the CPU usage has ramped up contatntly around 25% and sometimes around 40% for a consiserable amount of time.
I have been looking at 'sh proc' and 'sh proc cpu-hog' and I can see that 'dispatch unit' takes up most of the cpu.
Is it possible someone can advise me what this is? Also would you advise a bigger unit?
Matt
Process: Dispatch Unit, NUMHOG: 1639, MAXHOG: 508, LASTHOG: 510
LASTHOG At: 15:01:10 UTC Oct 23 2006
PC: 2f1dce
Traceback: 2f1b30 2f568c 2ee167 745cba 73b465 c2d5e5 c2db14
c2df24 73b20b 745fbf 74802d 626e15 21852a 11302f
10-23-2006 10:27 PM
you're on the wrong forum.
We don't cover pix or security.
This one is for application loadbalancing/caching.
Gilles.
10-30-2006 12:20 PM
Matt,
even though it's on the wrong forum: you probably have hit a bug. I have the same issue as you with 7.2(1.9) and ASA5520. In Bug Navigator you can find tons of open bugs.
Hope this helps
/David
CSCsg38186 ASA-5520 7.2.1(1.19) crash dispatch unit
CSCsg49825 Traceback in Thread Dispatch Unit (Old pc 0x00218bc7 ebp 0x01853738)
CSCsg42272 Traceback in Dispatch Unit, assert t->stack[0] == STKINIT failed ?
CSCsg40678 Active PIX in failover pair crashed at Dispatch Unit
CSCsg06300 PIX crash fequently with Thread Name: Dispatch Unit
CSCse61850 Reload with Thread Name: Dispatch Unit; eip==q931_utl:q931_parse+154
CSCsg15416 Traceback in Dispatch Unit - w/ vpn-filter applied to IPSec connection
CSCsf32050 ASA reloads in Dispatch Unit thread
CSCsg08725 Crash in Dispatch Unit while timing out TCP keepalive message
