what is the distance of the between these 2 switches ? you can use multimode cable if it less than 200 meters.
if you make them as port-channel the fibre is different route yes, you have covered the redundency part.
If you laying the cables in path between floors, then you do not have diverce route. if the cable cut happends you will have downtime between floors.
