Question about SSL initiation
nygenxny123
Level 7
Level 7
it seems that basically you configure ssl proxy client under layer 7 map
and a parameter map if you are concerned about keys
but does the ACE initiatiate based on IP address of the server and not the common name of the website/cert?
and wouldnt this cause an error?
What about Trusted Authorities? how will the ACE know if this is a trusted cert
And key validation
We have implemented ssl initation without any issues with just the "ssl proxy client x" command under layer 7
but now we are having issues with another implementation and the developers are wondering about the questions i just posted
Daniel Arrondo Ostiz
Good afternoon,
it seems that basically you configure ssl proxy client under layer 7 map and a parameter map if you are concerned about keys
Yes, this is the only thing that is required for the most basic setup
As you said, the ssl-proxy client is configured under a L7 map, and therefore, you can do any L7 load-balancing decisions before you choose the serverfarm to which the connection will go. At this point you could match on the hostname of the original HTTP request and based on that send the connection to one farm or another
By default, the ACE will only check if the certificate is a server one and not expired, but you can also configure the ACE to test it against a set of preconfigured certificate authorities. For more details, check http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/ssl/guide/initiate.html#wp1084113
If you have any other questions, please, do not hesitate to contact me again
Daniel
Good afternoon,
Daniel
thx!
