07-21-2015 03:15 PM
I couldn't find the DVD to install virtual Central Manager (vCM-100N) on a ESX server. Is there a link where I can download the VM image? Here is a download link, but I didn't see vCM anywhere.
https://software.cisco.com/download/release.html?mdfid=280484571&flowid=122&softwareid=280836712&release=5.3.5d&relind=AVAILABLE&rellifecycle=&reltype=latest
We are going to use ISR (4331 and 4351) with WAAS module for all sites but I couldn't find a part number for SRE module. Can someone help me with that info?
If ISR uses SRE module to perform WAAS, is WAAS feature embedded in the router IOS universal image and enabled by AppX license? In other words, there's no need to download ISR OVA files in the previous download link and install on SRE module. Correct?
Gary
Solved! Go to Solution.
08-04-2015 08:13 AM
Hi Gary,
1) You cannot download vCM images, you'll need to purchase it and you'll get a CD/DVD.
Contact your account manager or if you're a partner contact PDI helpdesk.
2) ISR4000 series are not compatible with SRE modules - they are for ISR G2 only
You can use ISR-WAAS (which runs in a virtual container on the ISR-4000, and requires a NIM module with SSD/HDD) or you can install a UCS-E blade in the ISR-4331 or 4351 and install ESX and run vWAAS (not ISR-WAAS).
For the ISR-WAAS, I think you can order the routers with ISRWAAS preinstalled, but it is as such not part of IOS, it runs in a separate virtual container (the APPNAV-X is part of IOS-XE)
Best Regards
Finn
08-04-2015 08:13 AM
Hi Gary,
Best Regards
Finn
03-06-2017 05:18 AM
just for the archive, I'm Select Partner and contacted the PDI, but this status is also not enough:
To access the PDI Technical Advisors your company needs to hold at least one of the required Cisco specializations for the respective technology below. Entitlement is confirmed using the Partner Locator Tool on Cisco.com:
WAN optimization Cases:
Advanced Enterprise Network Architecture
Advanced Unified Access Specialization
Master Enterprise Networks
Cisco Distributors
Approved Ecopartners
I'm now in touch with my Distributor ...
03-09-2017 12:01 AM
Hi Gary,
Actually I notices that, for the new release 6.2.3b, you can download the ESXi image (ova-file) for VCM-100N.
And if you want an earlier release, you can always downgrade, using the universal bin image.
Best Regards
Finn
