08-28-2005 08:28 PM
I'm sorry if this appears twice, but I thought I had sent early and now cannot find.
I have looked at the documentation on how to set up redundant CSM but all seems to use full IOS. I have a CatOS hybrid system and just need clarification on one point I think.
The documentation calls to set up a Fault-tolerant VLAN by using the commands:
Vlan 9
ft-group 1 vlan 9
How do I replicate this command under CatOS? I cannot see a way to do this.
Is it really required? I can't see how it works otherwise
Many Thanks
LP
08-28-2005 10:35 PM
the first command is to make sure the vlan exist on the catalyst.
In hybride you will do 'set vlan 9'
The next command is a CSM command and should be same.
Gilles.
Thanks for rating.
08-28-2005 10:52 PM
duh! U know, some days one just shouldn't go to work!
Thanks Gilles worked a treat
