SCA SSL problems with IE on Mac platofrms
awo
Anybody here expirienced any problems with SSL working on IE for MacOS ?
We have moved SSL encryption from windows NT server to SCA and the MacOS station with MS IE stops working correctly giving error:
"Unable to establish a secure connection to (our website).
There is a problem with the security certificate from the
that site (the identity certificate issuer is unknown.)
The information you view and send will be readable to
others while in transit, and it may not go to the intended
party. Continue loading this page?"
I can click ok and continue to the page I requested and
the protocol changes to HTTPS, however I do not have the
secure connection "lock" icon in the corner of the browser
window.
Gilles Dufour
I guess this is the problem related to a case that was recently open with the TAC.
Did you try to contact microsoft for this problem ?
Because I remember doing a test with Netscape on the same platform and it was working fine.
Also, you should capture a sniffer trace and see the difference between packets with and without an SCA.
